I have created a new rule in the NGRE and am using the dayset condition. I am getting an error in the logs:
f96ac94a-d014-46ab-ba20-013104ee9d20 updated: UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Getting handler 'ephemeris.WeekdayCondition' for module '3' failed: Config parameter 'offset' is missing in the configuration of module '3'.
The item name suggest you have simple mode turned on. Save yourself a big headache by turning this off so you can give each item a proper name that matches it’s description.
Hardly, I’ve only used JSONDB Rules a little bit and honestly do not recommend their general use until OH 3 comes out.
Have you configured Ephemeris? It’s under Configuration -> System. Make sure you set the weekend days and supply your country and region (and city if applicable, if there is no drop down list there isn’t a valid city to enter).
There are a bunch of bugs in PaperUI, one of which might even be that the dayset condition may itself just be broken. But it for sure won’t work if ephemeris isn’t configured correctly.
I think we are facing a bug here. May I ask you to file an issue here? Thanks.
Why? First of all the offsetis not required it should not throw an exception at all. The code checks on the value for instanceof Integer. This is not sufficient. We should consider other numerical types too.
