I’ve update my Niko home Control installation to version 2.26.4 Since then all things behind the niko home bridge have ERR:COM. The bridge itself is still ONLINE.
I’ve another niko home control bridge which is still on older version 2.26.1. This one is still working ok.
On the logging I see only the fact the niko discovery service is not connected.
A subscriber of type ‘class org.openhab.binding.nikohomecontrol.internal.protocol.nhc2.NikoHomeControlCommunication2’ failed to process message '7B22506172616D73223A5B7B2244657669636573223A5B7B2255756964223A2239343639303036302D646438322D343736362D383865662D663630666466396533393261222C224964656E7469… cut
was caused by a integration of ABB EV charger. THe ABB EV charger is not connected in the Niko home control programm. The new version send empty definition. Old version porbably not. Niko binding should be able to skip the definition and not crash the binding.
For me not a problem as the ABB EV charger was not needed : just reomved the integration from the sw porgram and uploaded the new definition
Do you have a log of the empty response that crashed the binding? You can send it in a PM. I can check where it crashed then and correct it. I see it is cut in your previous message, I need to full response to be able to correct it and see where it failed.
