with the latest version, trying to change temperature and mode
2019-01-10 17:24:01.868 [DEBUG] [org.openhab.binding.nikohomecontrol ] - BundleEvent [unknown:512] - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:01.895 [DEBUG] [org.openhab.binding.nikohomecontrol ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=123, service.bundleid=201, service.scope=bundle, component.name=org.openhab.binding.nikohomecontrol.internal.NikoHomeControlHandlerFactory, component.id=15} - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:02.295 [DEBUG] [org.openhab.binding.nikohomecontrol ] - BundleEvent STARTING - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:02.301 [DEBUG] [org.openhab.binding.nikohomecontrol ] - BundleEvent STARTED - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:03.489 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: bridge discovery service started
2019-01-10 17:24:03.492 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: Start background bridge discovery
2019-01-10 17:24:03.498 [DEBUG] [org.openhab.binding.nikohomecontrol ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=154, service.bundleid=201, service.scope=bundle, component.name=org.openhab.binding.nikohomecontrol.internal.discovery.NikoHomeControlBridgeDiscoveryService, component.id=14} - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:03.505 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: discovery broadcast on 192.168.123.255
2019-01-10 17:24:03.527 [DEBUG] [nal.protocol.NikoHomeControlDiscover] - Niko Home Control: IP address is /192.168.123.184, unique ID is 443b00ee4b2a
2019-01-10 17:24:03.529 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: NHC II bridge found at /192.168.123.184
2019-01-10 17:24:04.486 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-01-10 17:24:04.531 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-01-10 17:24:14.123 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-10 17:24:15.331 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'nikohomecontrol:bridge2:443b00ee4b2a' to inbox.
2019-01-10 17:24:15.588 [DEBUG] [very.NikoHomeControlDiscoveryService] - Niko Home Control: discovery service org.openhab.binding.nikohomecontrol.internal.handler.NikoHomeControlBridgeHandler2@15f80e6
2019-01-10 17:24:15.592 [DEBUG] [org.openhab.binding.nikohomecontrol ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=308, service.bundleid=201, service.scope=singleton} - org.openhab.binding.nikohomecontrol
2019-01-10 17:24:16.260 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.123.204:8080
2019-01-10 17:24:16.263 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.123.204:8443
2019-01-10 17:24:17.181 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-01-10 17:24:33.576 [DEBUG] [andler.NikoHomeControlBridgeHandler2] - Niko Home Control: initializing NHC II bridge handler
2019-01-10 17:24:33.579 [DEBUG] [andler.NikoHomeControlBridgeHandler2] - Niko Home Control: touch profile openhab
2019-01-10 17:24:33.583 [DEBUG] [andler.NikoHomeControlBridgeHandler2] - Niko Home Control: clientid 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a, userdata folder /var/lib/openhab2
2019-01-10 17:24:33.605 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: base persistence path set to /var/lib/openhab2/nikohomecontrol
2019-01-10 17:24:33.633 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: initializing for mqtt connection to CoCo on 192.168.123.184:8883
2019-01-10 17:24:33.646 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: persistence path set to /var/lib/openhab2/nikohomecontrol/127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-public
2019-01-10 17:24:33.781 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.123.184' with clientid 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-public and file store '/var/lib/openhab2/nikohomecontrol/127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-public'
2019-01-10 17:24:34.109 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-public
2019-01-10 17:24:34.112 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish public/system/cmd, {"Method":"systeminfo.publish","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.120 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-public
2019-01-10 17:24:34.121 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish public/authentication/cmd, {"Method":"profiles.list","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.181 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic public/system/rsp, payload {"Method":"systeminfo.publish","Params":[{"SystemInfo":[{"LastConfig":"20190110162113","WaterTariff":"0","Currency":"EUR","Units":"0","Language":"NL","SWversions":[{"NhcVersion":"2.3.2.8931"},{"CocoImage":"2018.3-20181121105246"}],"ElectricityTariff":"0","GasTariff":"0"}]}]}
2019-01-10 17:24:34.187 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic public/authentication/rsp, payload {"Method":"profiles.list","Params":[{"Profiles":[{"Name":"openhab","Type":"Touch","Uuid":"4faaca81-4034-494d-afc3-b7d2c676039f"},{"Name":"default","Type":"Touch","Uuid":"4cb93514-6414-4efb-93c7-def2b6ff5eb2"},{"Name":"test","Type":"Touch","Uuid":"e4f19813-555e-494b-8306-c735dde10860"}]}]}
2019-01-10 17:24:34.220 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: persistence path set to /var/lib/openhab2/nikohomecontrol/127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:34.253 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.123.184' with clientid 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile and file store '/var/lib/openhab2/nikohomecontrol/127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile'
2019-01-10 17:24:34.451 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:34.453 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/authentication/cmd, {"Method":"services.list","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.455 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:34.457 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/control/devices/cmd, {"Method":"devices.list","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.460 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:34.462 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/control/locations/cmd, {"Method":"locations.list","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.464 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:34.467 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/notification/cmd, {"Method":"notifications.list","ErrCode":"","ErrMessage":""}
2019-01-10 17:24:34.467 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic 4faaca81-4034-494d-afc3-b7d2c676039f/authentication/rsp, payload {"Method":"services.list","Params":[{"Services":[{"Name":"control"},{"Name":"authentication"},{"Name":"system"}]}]}
2019-01-10 17:24:35.234 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic 4faaca81-4034-494d-afc3-b7d2c676039f/control/devices/rsp, payload {"Method":"devices.list","Params":[{"Devices":[{"Properties":[{"OverruleActive":"False"},{"SetpointTemperature":"14.00"},{"OverruleSetpoint":"20.00"},{"OverruleTime":"60"},{"Program":"Night"},{"EcoSave":"False"},{"Demand":"None"},{"AmbientTemperature":"15.50"}],"Name":"Thermostaat Living","Technology":"nikohomecontrol","Uuid":"d4187ab8-194b-492e-9770-6d1e986134f9","Identifier":"bc668b6b-997e-4a51-b800-3ece94e3f574","PropertyDefinitions":[{"OverruleActive":{"Description":"Boolean","HasStatus":"true","CanControl":"true"}},{"SetpointTemperature":{"Description":"Range(5.00,30.00,0.50)","HasStatus":"true","CanControl":"false"}},{"OverruleSetpoint":{"Description":"Range(5.00,30.00,0.50)","HasStatus":"true","CanControl":"true"}},{"OverruleTime":{"Description":"Range(1.00,1439.00,1.00)","HasStatus":"true","CanControl":"true"}},{"Program":{"Description":"Choice(Day,Night,Eco,Off,Cool,Prog1,Prog2,Prog3)","HasStatus":"true","CanControl":"true"}},{"EcoSave":{"Description":"Boolean","HasStatus":"true","CanControl":"true"}},{"Demand":{"Description":"Choice(Heating,Cooling,None)","HasStatus":"true","CanControl":"false"}},{"AmbientTemperature":{"Description":"Range(-5.00,45.00,0.50)","HasStatus":"true","CanControl":"false"}}],"Online":"True","Model":"thermostat","Traits":[{"MacAddress":"004a1036"}],"Type":"thermostat","Parameters":[{"LocationId":"68d0600a-d31d-495e-bda1-d930c6eab29f"},{"LocationName":"Living"},{"LocationIcon":"general"}]}]}]}
2019-01-10 17:24:35.247 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: adding thermostatdevice Thermostaat Living
2019-01-10 17:24:35.271 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: setting thermostat d4187ab8-194b-492e-9770-6d1e986134f9 with measured 155, setpoint 140, mode 1, overrule 0, overruletime 0, ecosave 0
2019-01-10 17:24:35.272 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: Communication start complete.
2019-01-10 17:24:35.277 [DEBUG] [handler.NikoHomeControlBridgeHandler] - Niko Home Control: restart bridge connection every 300 min
2019-01-10 17:24:35.283 [DEBUG] [very.NikoHomeControlDiscoveryService] - Niko Home Control: getting devices on 443b00ee4b2a
2019-01-10 17:24:35.290 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9' to inbox.
2019-01-10 17:24:38.726 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: thermostat intialized d4187ab8-194b-492e-9770-6d1e986134f9
2019-01-10 17:24:38.772 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command REFRESH for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:measured
2019-01-10 17:24:38.785 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command REFRESH for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:mode
2019-01-10 17:24:38.792 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command REFRESH for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:setpoint
2019-01-10 17:24:38.794 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command REFRESH for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:overruletime
2019-01-10 17:24:46.200 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command 0 for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:mode
2019-01-10 17:24:46.205 [DEBUG] [nternal.protocol.nhc2.NhcThermostat2] - Niko Home Control: execute thermostat mode 0 for d4187ab8-194b-492e-9770-6d1e986134f9
2019-01-10 17:24:46.209 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:46.212 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/control/devices/cmd, {"Method":"devices.control","ErrCode":"","ErrMessage":"","Params":[{"Devices":[{"Uuid":"d4187ab8-194b-492e-9770-6d1e986134f9","Properties":[{"Program":"Day","OverruleActive":"False"}]}]}]}
2019-01-10 17:24:46.756 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic public/system/evt, payload {"Method":"time.published","Params":[{"TimeInfo":[{"GMTOffset":"3600","Timezone":"Europe/Brussels","IsDST":"0","UTCTime":"20190110162446"}]}]}
2019-01-10 17:24:46.760 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Niko Home Control: received topic 4faaca81-4034-494d-afc3-b7d2c676039f/system/evt, payload {"Method":"time.published","Params":[{"TimeInfo":[{"GMTOffset":"3600","Timezone":"Europe/Brussels","IsDST":"0","UTCTime":"20190110162446"}]}]}
2019-01-10 17:24:58.482 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command 60 for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:overruletime
2019-01-10 17:24:58.487 [DEBUG] [nternal.protocol.nhc2.NhcThermostat2] - Niko Home Control: execute thermostat overrule 140 during 60 min for d4187ab8-194b-492e-9770-6d1e986134f9
2019-01-10 17:24:58.493 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:58.496 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/control/devices/cmd, {"Method":"devices.control","ErrCode":"","ErrMessage":"","Params":[{"Devices":[{"Uuid":"d4187ab8-194b-492e-9770-6d1e986134f9","Properties":[{"OverruleActive":"True","OverruleSetpoint":"14","OverruleTime":"60"}]}]}]}
2019-01-10 17:24:58.905 [DEBUG] [ler.NikoHomeControlThermostatHandler] - Niko Home Control: handle command 18 °C for nikohomecontrol:thermostat:443b00ee4b2a:d4187ab8-194b-492e-9770-6d1e986134f9:setpoint
2019-01-10 17:24:58.910 [DEBUG] [nternal.protocol.nhc2.NhcThermostat2] - Niko Home Control: execute thermostat overrule 180 during 60 min for d4187ab8-194b-492e-9770-6d1e986134f9
2019-01-10 17:24:58.915 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: connection state CONNECTED for 127_0_1_1-nikohomecontrol_bridge2_443b00ee4b2a-profile
2019-01-10 17:24:58.920 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - Niko Home Control: publish 4faaca81-4034-494d-afc3-b7d2c676039f/control/devices/cmd, {"Method":"devices.control","ErrCode":"","ErrMessage":"","Params":[{"Devices":[{"Uuid":"d4187ab8-194b-492e-9770-6d1e986134f9","Properties":[{"OverruleActive":"True","OverruleSetpoint":"18","OverruleTime":"60"}]}]}]}
2019-01-10 17:25:03.546 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: discovery broadcast on 192.168.123.255
2019-01-10 17:25:03.556 [DEBUG] [nal.protocol.NikoHomeControlDiscover] - Niko Home Control: IP address is /192.168.123.184, unique ID is 443b00ee4b2a
2019-01-10 17:25:03.560 [DEBUG] [ikoHomeControlBridgeDiscoveryService] - Niko Home Control: NHC II bridge found at /192.168.123.184
