@blatruwe Great to hear. Thatās what I intended to happen. Make sure you check all combinations: select program, set overrule with and without time etc. All of that should work from whatever control you do it (OH, touchscreen, wall control) in any sequence. If you find any sequence that does not behave, let me know.
I also expect ambient temperature to update. So the temperature channel should always give you the current room temperature.
Btw, integration with Google Assistant works great. Please note that it is not supported in Flemish yet but you can download the APK and speak dutch (not flemish) to the assistant.
Install the Openhab cloud connector via Paper UI - Add Ons - Misc
I just posted a new version that has support for more action models. Models like socket and pir should now also work.
You may have to remove your things and add them again to have the correct behaviour. They should then also show the model and technology in the properties.
I see you copied the thermostat items from the help page but you are missing some needed tags. Also Iām not sure if you can control the override time with a voice command like this. I think asking the current temperature and setting wanted temperature should be doable. Maybe change prog? You should try it and let us know!
If you expose thermostats make sure than you have:
A group item with the tag [ "Thermostat" ]
A number or string item with the tag [ "homekit:HeatingCoolingMode" ]
A number item with the tag [ "CurrentTemperature" ]
A number ityem with the tag [ "TargetTemperature" ]
Please check the FAQ on the bottom of this page:
PS: I use Visual Studio Code to create all files for Openhab, it has a syntax check and autocomplete for many things so you canāt really make typoās. This tutorial is very helpful.
@bccrew: ha indeed, I forgot the tags. Using VSC also, showed no syntax errors though. But not for tonight anymore. Somehow the Google assistant link to openhab was gone. Re-associating did not work. Going to reinvestigate another time.
Also, the socket show up as switch, but I cannot create an item on the channel (does not show up in the logs also somehow?). It shows a pop-up Internal Server Error 500 for a very short time.
@cwegh For, the pir, can you get me the trace log at binding start? Curious to see what goes wrong. From its definition, I was assuming it was pretty much the same as other devices that need to be triggered.
Revisited the thread after a while here, good lord, you guys got allot figured out in a short time.
I installed openhab on my server today but i dont get the Niko Bindings, I got the Jar file in the addon folder; restartedā¦ not sure what i forget or doing wrong. is there a step by step somewhere to get me going?
@Bjorn_Embrechts Happy to see you join the testing.
We are not there yet. There is a lot working, but we also still see quite a few stability problems. But the more testing that is done, the more chance we have to figure it out.
The binding itself should work out of the box without much configuration. Donāt install the Niko Binding from the release (that is just NHC I). If you have already, uninstall that through PaperUI. Copy the binding jar, referenced up in this thread into the addons folder. Your CoCo should appear in your inbox. Accept it, and all your devices should appear in the inbo. Accept the ones you want to control.
Check the openhab.log and events.log file for any hints if this does not work.
You can switch logging to a higher logging level (DEBUG or even TRACE) to get more info. You can do that from the Karaf console, see up in this thread and the documentation. There currently is an issue when people switch back from DEBUG to DEFAULT log level. The bridge does not come back online anymore. I am curious if this is true for everyone, or just a timing issue for some users. Therefore also, please test if it comes online before switching logging to a higher level. Maybe it only happens when you switch back.
Did you follow all instructions like described here:
Read a few posts back here where I described the correct tagging of items. Itās always best to manually create items instead of linking them through Paper UI.
I donāt have thermostats, so cannot test. But I assume you have to create an extra item and some rules to map the Niko modes to the required homekit modes, as used by Google Assistant.
Here is an example for something similar for KNX: Google Home & openHAB connection How-To
The modes used by the binding for Niko are numbers, and documented in the binding doc (same for nhc I and II).
