Here is how I have it configured (note: I am still on OH2, but I think it will work on OH3 as well):
things/nilan.things:
Bridge modbus:tcp:nilan [ host="10.0.0.107", port=502 ] {
Bridge poller NilanTemperatures [ start=5152, length=12, refresh=10000, type="input" ] {
Thing data Nilan_Temp_T1_Outdoor [ readStart="5152", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T2_Supply [ readStart="5153", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T3_Extract [ readStart="5154", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T4_Discharge [ readStart="5155", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T5_Condenser [ readStart="5156", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T6_Evaporator [ readStart="5157", readValueType="int16", readTransform="JS(divide10.js)" ]
//Thing data Nilan_Temp_T7_AfterHeat [ readStart="5158", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T11_HotWaterTop [ readStart="5162", readValueType="int16", readTransform="JS(divide10.js)" ]
Thing data Nilan_Temp_T12_HotWaterBot [ readStart="5163", readValueType="int16", readTransform="JS(divide10.js)" ]
Bridge poller NilanDHWSetpoint [ start=5548, length=1, refresh=10000, type="input" ] {
Thing data Nilan_Temp_DWH_Setpoint [ readStart="5548", readValueType="int16", readTransform="JS(divide10.js)" ]
Bridge poller NilanRegulationMode [ start=5432, length=1, refresh=10000, type="input" ] {
Thing data Nilan_Enum_RegulationMode [ readStart="5432", readValueType="uint16" ]
Bridge poller NilanHumiditySensor [ start=4716, length=1, refresh=10000, type="input" ] {
Thing data Nilan_Humidity_Sensor [ readStart="4716", readValueType="uint16" ]
Bridge poller NilanFilterMonitor [ start=1326, length=4, refresh=10000, type="input" ] {
Thing data Nilan_Filter_InletInterval [ readStart="1326", readValueType="uint16" ]
Thing data Nilan_Filter_OutletInterval [ readStart="1327", readValueType="uint16" ]
Thing data Nilan_Filter_InletDaysLeft [ readStart="1328", readValueType="uint16" ]
Thing data Nilan_Filter_OutletDaysLeft [ readStart="1329", readValueType="uint16" ]
Bridge poller Nilan_reg_4692 [ start=4692, length=2, refresh=10000, type="input" ] {
Thing data NilanThing_Inlet_Filter [ readStart="4692", readValueType="uint16" ]
Thing data NilanThing_Outlet_Filter [ readStart="4693", readValueType="uint16" ]
Bridge poller Nilan_DHW_Settings [ start=3938, length=1, refresh=10000, type="holding" ] {
//Thing data Nilan_DHW_ElectricHeaterSetpoint [ readStart="3935", readValueType="int16", readTransform="JS(divide10.js)", writeStart="3935", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data Nilan_DHW_ElectricHeaterEnable [ readStart="3938", readValueType="int16", writeStart="3938", writeValueType="int16", writeType="holding" ]
Bridge poller Nilan_reg_2402 [ start=2402, length=6, refresh=20000, type="holding" ] {
Thing data NilanThing_Operation_Mode [ readStart="2402", readValueType="int16", writeStart="2402", writeValueType="int16", writeType="holding" ]
Thing data NilanThing_Inlet_Temperature_Max [ readStart="2403", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2403", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_Temp_Min_Summer_Inlet [ readStart="2404", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2404", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_Temp_Min_Winter_Inlet [ readStart="2405", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2405", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_Temp_Summer_Winter_Threshold [ readStart="2406", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2406", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_Temp_Summer_Winter_Offset [ readStart="2407", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2407", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Bridge poller Nilan_reg_2832 [ start=2832, length=5, refresh=10000, type="holding" ] {
Thing data NilanThing_ExtOp1_AirTemp [ readStart="2832", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2832", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_ExtOp1_DWHTemp [ readStart="2833", readValueType="int16", readTransform="JS(divide10.js)", writeStart="2833", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data NilanThing_ExtOp1_Flags [ readStart="2834.0", readValueType="uint8" ]
Thing data NilanThing_ExtOp1_ExhaustSpeed [ readStart="2834.1", readValueType="uint8" ]
Thing data NilanThing_ExtOp1_SupplySpeed [ readStart="2835.0", readValueType="uint8" ]
Thing data NilanThing_ExtOp1_Duration [ readStart="2836", readValueType="int16", writeStart="2833", writeValueType="int16", writeType="holding" ]
Bridge poller Nilan_reg_4746 [ start=4746, length=2, refresh=11000, type="holding" ] {
Thing data Nilan_Temp_User_Setpoint [ readStart="4746", readValueType="int16", readTransform="JS(divide10.js)", writeStart="4746", writeValueType="int16", writeType="holding", writeTransform="JS(multiply10.js)" ]
Thing data Nilan_User_Fan_Speed [ readStart="4747", readValueType="int16", writeStart="4747", writeValueType="int16", writeType="holding" ]
Bridge poller Nilan_reg_4999 [ start=4699, length=3, refresh=10000, type="input" ] {
Thing data NilanThing_Inlet_Fan_Speed [ readStart="4699", readValueType="uint16" ]
Thing data NilanThing_Outlet_Fan_Speed [ readStart="4700", readValueType="uint16" ]
Thing data NilanThing_Heater_Device [ readStart="4701", readValueType="uint16" ]
transform/divide10.js:
// Wrap everything in a function (no global variable pollution)
// variable "input" contains data passed by openHAB
(function(inputData) {
// on read: the polled number as string
// on write: openHAB command as string
var DIVIDE_BY = 10;
return parseFloat(inputData) / DIVIDE_BY;
})(input)
transform/multiply10.js:
(function(i) {
return Math.round(parseFloat(i, 10) * 10);
})(input)
// input variable contains data passed by openhab
items/nilan.items:
Group gNilanLog
Number Nilan_T1_Outdoor "Udeluft [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T1_Outdoor:number" }
Number Nilan_T2_Supply "Tilluft [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T2_Supply:number" }
Number Nilan_T3_Extract "Fraluft [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T3_Extract:number" }
Number Nilan_T4_Discharge "Afkastluft [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T4_Discharge:number" }
Number Nilan_T5_Condenser "Kondensator [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T5_Condenser:number" }
Number Nilan_T6_Evaporator "Fordamper [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T6_Evaporator:number" }
Number Nilan_T11_HotWaterTop "Vandvarmer Top [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T11_HotWaterTop:number" }
Number Nilan_T12_HotWaterBot "Vandvarmer Bund [%.1f °C]" (gNilanLog) { channel="modbus:data:nilan:NilanTemperatures:Nilan_Temp_T12_HotWaterBot:number" }
Number Nilan_DHW_Setpoint "Vandtemperatur setpunkt [%.0f °C]" { channel="modbus:data:nilan:NilanDHWSetpoint:Nilan_Temp_DWH_Setpoint:number" }
Number Nilan_RegulationMode "Regulation mode [%d]" { channel="modbus:data:nilan:NilanRegulationMode:Nilan_Enum_RegulationMode:number" }
Number Nilan_InletFilter_ChangeInterval "Filter interval ind [%d d]" { channel="modbus:data:nilan:NilanFilterMonitor:Nilan_Filter_InletInterval:number" }
Number Nilan_OutletFilter_ChangeInterval "Filter interval ud [%d d]" { channel="modbus:data:nilan:NilanFilterMonitor:Nilan_Filter_OutletInterval:number" }
Number Nilan_InletFilter_DaysLeft "Filterkapacitet tilbage ind [%d d]" { channel="modbus:data:nilan:NilanFilterMonitor:Nilan_Filter_InletDaysLeft:number" }
Number Nilan_OutletFilter_DaysLeft "Filterkapacitet tilbage ud [%d d]" { channel="modbus:data:nilan:NilanFilterMonitor:Nilan_Filter_OutletDaysLeft:number" }
Number Nilan_Inlet_Filter "Filterkapacitet ind [%d %%]" { channel="modbus:data:nilan:Nilan_reg_4692:NilanThing_Inlet_Filter:number" }
Number Nilan_Outlet_Filter "Filterkapacitet ud [%d %%]" { channel="modbus:data:nilan:Nilan_reg_4692:NilanThing_Outlet_Filter:number" }
Number Nilan_Operation_Mode "Driftstilstand [MAP(nilan_opmode.map):%s]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Operation_Mode:number" }
Number Nilan_Inlet_Temperature_Max "Inlet temp max [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Inlet_Temperature_Max:number" }
Number Nilan_Temp_Min_Summer_Inlet "Summer inlet min [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Temp_Min_Summer_Inlet:number" }
Number Nilan_Temp_Min_Winter_Inlet "Winter inlet min [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Temp_Min_Winter_Inlet:number" }
Number Nilan_Temp_Summer_Winter_Threshold "Sommer/Vinter threshold [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Temp_Summer_Winter_Threshold:number" }
Number Nilan_Temp_Summer_Winter_Offset "Sommer/Vinter offset [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2402:NilanThing_Temp_Summer_Winter_Offset:number" }
Number Nilan_ExtOp1_AirTemp "ExtOp1 lufttemp [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_AirTemp:number" }
Number Nilan_ExtOp1_DWHTemp "ExtOp1 DWH temp [%.1f °C]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_DWHTemp:number" }
Number Nilan_ExtOp1_Flags "ExtOp1 flags [%x]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_Flags:number" }
Number Nilan_ExtOp1_ExhaustSpeed "ExtOp1 Exhaust speed [%d]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_ExhaustSpeed:number" }
Number Nilan_ExtOp1_SupplySpeed "ExtOp1 Supply speed [%d]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_SupplySpeed:number" }
Number Nilan_ExtOp1_Duration "ExtOp1 Supply speed [%d]" { channel="modbus:data:nilan:Nilan_reg_2832:NilanThing_ExtOp1_Duration:number" }
Number Nilan_Inlet_Fan_Speed "Inlet fan speed [%d %%]" (gNilanLog) { channel="modbus:data:nilan:Nilan_reg_4999:NilanThing_Inlet_Fan_Speed:number" }
Number Nilan_Outlet_Fan_Speed "Outlet fan speed [%d %%]" (gNilanLog) { channel="modbus:data:nilan:Nilan_reg_4999:NilanThing_Outlet_Fan_Speed:number" }
Number Nilan_Heater_Device "Heater device [%d %%]" { channel="modbus:data:nilan:Nilan_reg_4999:NilanThing_Heater_Device:number" }
Number Nilan_Humidity_Average "Average humidity [RH %d%%]" (gNilanLog) { channel="modbus:data:nilan:NilanHumiditySensor:Nilan_Humidity_Sensor:number" }
Switch Nilan_DHW_Electric_Heater "DHW Elsupplering" { channel="modbus:data:nilan:Nilan_DHW_Settings:Nilan_DHW_ElectricHeaterEnable:switch" }
Number Nilan_User_Temperature_Setpoint "Temperature setpoint" { channel="modbus:data:nilan:Nilan_reg_4746:Nilan_Temp_User_Setpoint:number" }
Number Nilan_User_Fan_speed "Fan speed [%d %%]" { channel="modbus:data:nilan:Nilan_reg_4746:Nilan_User_Fan_Speed:number" }
And a snippet from the sitemap, although not fully implemented, but can read out temperatures, and change a few parameters, e.g. the fan speed:
Frame label="Nilan" {
Default item=Nilan_T1_Outdoor icon="temperature"
Default item=Nilan_T2_Supply icon="temperature"
Default item=Nilan_T3_Extract icon="temperature"
Default item=Nilan_T4_Discharge icon="temperature"
Default item=Nilan_T5_Condenser icon="temperature"
Default item=Nilan_T6_Evaporator icon="temperature"
Default item=Nilan_T11_HotWaterTop icon="temperature"
Default item=Nilan_T12_HotWaterBot icon="temperature"
Default item=Nilan_DHW_Setpoint icon="heating"
Default item=Nilan_RegulationMode icon="text"
Text item=Nilan_InletFilter_ChangeInterval icon="settings"
Text item=Nilan_OutletFilter_ChangeInterval icon="settings"
Text item=Nilan_InletFilter_DaysLeft icon="shield"
Text item=Nilan_OutletFilter_DaysLeft icon="shield"
Default item=Nilan_Humidity_Average icon="humidity"
Default item=Nilan_DHW_Electric_Heater
Setpoint item=Nilan_User_Temperature_Setpoint icon="heating" minValue=15 maxValue=28 step=1
Switch item=Nilan_User_Fan_speed icon="fan" mappings=[ 101="1", 102="2", 103="3", 104="4"]
