No access to local server via iOS App
At system setting in iOS App my local server configuration doesn’t work anymore.
Neither http://localserver:8080 nor https://localserver:8443
Everything else is working well: iOS access via remote server or access via browser for example to localserver:8080/overview.
Any hint is appreciated
Did you enter localserver or is localserver the IP address of your server.
Please try with IP address.
No it’s the IP adress of the openHAB server (http://192.168.66.29:8080)
Have you tried the solution at App not working, but browser works - #9 by Hans_Lree
I finally found the solution. I didn’t grant access to the LAN in the iOS settings of the App :person_facepalming:t2:
