I recently reinstalled openhab2.2. I am able to successfully see my panel pages and everything looks to be working fine.
However, when I go to custom widgets and try to open one of my custom widget in order to edit - I don’t see any data(like below):
Has anyone experienced that before?
What is the best way to do in such situation? I could probably export and import that files manually, but I would rather avoid such manual work.
I’ve got the same problem. The code is all there, you just can’t see it. Select all, copy, and past into an editor to change and then past back. I’ve tried a few things but nothing seems to help.
