Hi after update and upgrade and clear cache can’t use clients(in my home-sonoffs switches and wemos-Tasmota firmware and use MQTT).
But openhab cloud works
can control my smart tv with the binding
can see changes with network binding( if my phone’s wifi is conecting)
Can send commands with mqttSpy and receive and connect to rasp(192.168.1.43) mqtt server
Ip = 192.168.1.43
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Uptime = 0 day(s). 0:0:21
CPU Usage = 96.98 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 1.78, 5m: 0.39, 15m: 0.13
Memory = Free: 0.86GB (91%), Used: 0.08GB (9%), Total: 0.94GB
Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
Root = Free: 10.17GB (74%), Used: 3.41GB (26%), Total: 14.19GB
Updates = 0 apt updates available.
Sessions = 1 sessions
Processes = 146 running processes of 32768 maximum processes
openHAB 2.5.0~M1-1 (Milestone Build)
2019-02-10 11:08:19.457 [vent.ItemStateChangedEvent] - Reboot changed from ON to OFF
2019-02-10 11:08:26.250 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:tv1' changed from OFFLINE: TV is off to UNINITIALIZED
2019-02-10 11:08:26.302 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:tv1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-10 11:08:26.309 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6' changed from OFFLINE: TV is off to UNINITIALIZED
2019-02-10 11:08:26.310 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-10 11:08:26.333 [hingStatusInfoChangedEvent] - 'network:pingdevice:76df602e' changed from ONLINE to UNINITIALIZED
2019-02-10 11:08:26.337 [hingStatusInfoChangedEvent] - 'network:pingdevice:76df602e' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-10 11:08:26.345 [hingStatusInfoChangedEvent] - 'network:pingdevice:5ca101b6' changed from ONLINE to UNINITIALIZED
2019-02-10 11:08:26.346 [hingStatusInfoChangedEvent] - 'network:pingdevice:5ca101b6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-10 11:08:26.894 [hingStatusInfoChangedEvent] - 'exec:command:1ad18136' changed from ONLINE to UNINITIALIZED
2019-02-10 11:08:26.897 [hingStatusInfoChangedEvent] - 'exec:command:1ad18136' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-10 11:08:26.940 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Mute => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:mute' has been removed.
2019-02-10 11:08:26.942 [temChannelLinkRemovedEvent] - Link 'iPhone_Location => icloud:device:myaccount:myiPhone8:location' has been removed.
2019-02-10 11:08:26.944 [temChannelLinkRemovedEvent] - Link 'iPhone_FindMyPhone => icloud:device:myaccount:myiPhone8:findMyPhone' has been removed.
2019-02-10 11:08:26.946 [temChannelLinkRemovedEvent] - Link 'Reboot => exec:command:1ad18136:run' has been removed.
2019-02-10 11:08:26.947 [temChannelLinkRemovedEvent] - Link 'iPhone_LocationLastUpdate => icloud:device:myaccount:myiPhone8:locationLastUpdate' has been removed.
2019-02-10 11:08:26.949 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Toast => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:toast' has been removed.
2019-02-10 11:08:26.950 [temChannelLinkRemovedEvent] - Link 'iPhone_BatteryLevel => icloud:device:myaccount:myiPhone8:batteryLevel' has been removed.
2019-02-10 11:08:26.952 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Channel => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:channelName' has been removed.
2019-02-10 11:08:26.953 [temChannelLinkRemovedEvent] - Link 'iPhone_LocationAccuracy => icloud:device:myaccount:myiPhone8:locationAccuracy' has been removed.
2019-02-10 11:08:26.970 [temChannelLinkRemovedEvent] - Link 'iPhone_Refresh => icloud:device:myaccount:myiPhone8:location' has been removed.
2019-02-10 11:08:26.971 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Stop => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:mediaStop' has been removed.
2019-02-10 11:08:26.973 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Player => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:mediaPlayer' has been removed.
2019-02-10 11:08:26.974 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Application => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:appLauncher' has been removed.
2019-02-10 11:08:26.976 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Power => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:power' has been removed.
2019-02-10 11:08:26.978 [temChannelLinkRemovedEvent] - Link 'LG_TV0_ChannelNo => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:channel' has been removed.
2019-02-10 11:08:26.980 [temChannelLinkRemovedEvent] - Link 'LG_TV0_Volume => lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:volume' has been removed.
2019-02-10 11:08:26.981 [temChannelLinkRemovedEvent] - Link 'iPhone_BatteryStatus => icloud:device:myaccount:myiPhone8:batteryStatus' has been removed.
2019-02-10 11:09:20.691 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-02-10 11:09:20.716 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : findMethod: Suitable but non-accessible method setScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-02-10 11:09:20.723 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : bind method [setScheduler] not found; Component will fail
2019-02-10 11:09:20.727 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : bind method [setScheduler] not found
2019-02-10 11:09:20.731 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-02-10 11:09:20.734 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : findMethod: Suitable but non-accessible method unsetScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-02-10 11:09:20.736 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : unbind method [unsetScheduler] not found; Component will fail
2019-02-10 11:09:20.741 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.oh250M1 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(86)] : unbind method [unsetScheduler] not found
2019-02-10 11:09:20.998 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-02-10 11:09:21.019 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Athens'.
2019-02-10 11:09:21.039 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '37.9337458,23.6355319'.
2019-02-10 11:09:21.055 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'el_GR'.
2019-02-10 11:09:30.949 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonoff.items'
2019-02-10 11:09:32.213 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2019-02-10 11:09:35.516 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-02-10 11:09:38.821 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'LgTvWEB.rules'
2019-02-10 11:09:39.115 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temp_humi.rules'
2019-02-10 11:09:41.477 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'motion_doors.rules'
2019-02-10 11:09:41.982 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'cortana _commands.rules'
2019-02-10 11:09:45.883 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lights_aleretur.rules'
2019-02-10 11:09:48.539 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'maintenance.rules'
2019-02-10 11:09:49.831 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'general.rules'
2019-02-10 11:09:52.276 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hydraulics.rules'
2019-02-10 11:09:53.233 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'general.sitemap'
2019-02-10 11:09:53.285 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Lampbed_B1_1.sitemap'
2019-02-10 11:09:53.328 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'LG_TV.sitemap'
2019-02-10 11:09:53.378 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lights.sitemap'
2019-02-10 11:09:53.457 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'settings.sitemap'
2019-02-10 11:09:53.512 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temp_hum.sitemap'
2019-02-10 11:09:53.553 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'LgTVWEB.sitemap'
2019-02-10 11:09:53.593 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'heater.sitemap'
2019-02-10 11:09:53.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'doors_motion.sitemap'
2019-02-10 11:09:53.661 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alarm.sitemap'
2019-02-10 11:09:54.066 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lgtv.things'
2019-02-10 11:09:54.262 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Mute-lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6:mute' has been added.
2019-02-10 11:09:54.751 [hingStatusInfoChangedEvent] - 'network:pingdevice:76df602e' changed from UNINITIALIZED to INITIALIZING
2019-02-10 11:09:54.861 [hingStatusInfoChangedEvent] - 'network:pingdevice:76df602e' changed from INITIALIZING to ONLINE
2019-02-10 11:09:54.885 [hingStatusInfoChangedEvent] - 'network:pingdevice:5ca101b6' changed from UNINITIALIZED to INITIALIZING
2019-02-10 11:09:54.966 [hingStatusInfoChangedEvent] - 'network:pingdevice:5ca101b6' changed from INITIALIZING to ONLINE
2019-02-10 11:09:54.989 [hingStatusInfoChangedEvent] - 'exec:command:1ad18136' changed from UNINITIALIZED to INITIALIZING
2019-02-10 11:09:55.010 [hingStatusInfoChangedEvent] - 'exec:command:1ad18136' changed from INITIALIZING to ONLINE
2019-02-10 11:09:55.970 [vent.ItemStateChangedEvent] - Iphone_Wifi_Online_elena changed from NULL to OFF
2019-02-10 11:09:55.967 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.43:8080
2019-02-10 11:09:55.974 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.43:8443
2019-02-10 11:09:55.977 [vent.ItemStateChangedEvent] - Iphone_time changed from NULL to -1.0
2019-02-10 11:09:55.980 [vent.ItemStateChangedEvent] - Iphone_time changed from -1.0 to UNDEF
2019-02-10 11:09:56.016 [vent.ItemStateChangedEvent] - Iphone_Wifi_Online_david changed from NULL to OFF
2019-02-10 11:09:56.020 [vent.ItemStateChangedEvent] - Iphone_time_david changed from NULL to -1.0
2019-02-10 11:09:56.023 [vent.ItemStateChangedEvent] - Iphone_time_david changed from -1.0 to UNDEF
2019-02-10 11:09:56.782 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-02-10 11:09:57.371 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2019-02-10 11:09:57.378 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2019-02-10 11:09:57.866 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6' changed from UNINITIALIZED to INITIALIZING
2019-02-10 11:09:57.885 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:28a5b38a-c59d-4010-ae4b-7ca9560787a6' changed from INITIALIZING to OFFLINE: TV is off
2019-02-10 11:09:57.902 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:tv1' changed from UNINITIALIZED to INITIALIZING
2019-02-10 11:09:57.909 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:tv1' changed from INITIALIZING to OFFLINE: TV is off
2019-02-10 11:09:58.147 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
2019-02-10 11:09:58.150 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2019-02-10 11:09:58.153 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
2019-02-10 11:09:58.918 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
Please some help!!!
