- Platform information:
- Hardware: Raspberry Pi 2 Model B Rev 1.1
- OS: Raspbian GNU/Linux 8 (jessie)
- Java Runtime Environment: 1.8.0_152
- openHAB version: openHABian 2
- Issue of the topic:
Hi there
I’m relatively new to openHAB, but I have some linux and coding experiences from some other projects. But not too much.
I had installed openHAB2 and mosquitto some months ago and played around with an WeMos D1 mini and my Android smartphone using MQTT Dash.
The binding between MQTT and OpenHAB worked fine. But one day my SDCard broke.
Now I reinstalled everything and configured openHAB2, mosquitto and also Node-RED.
Mosquitto and Node-RED works with the WeMos device, MQTT Dash and MQTT.fx.
But I for some reasons the binding between openHAB and mosquitto doesn’t exist, because when I toggle the switch in openHAB there is no reaction of mosquitto.
I tried and read a lot the last days, but I cannot find my mistake.
Do I need to edit the mqtt-eventbus.cfg? Or something else?
Hope someone of you can help…
Holger
- Please post configurations (if applicable):
Items configuration related to the issue
home.item
Switch D01R01In {mqtt=">[mosquitto:D01R01In:command:ON:1],>[mosquitto:D01R01In:command:OFF:0]"}
String D01R01Out “Status [%s]” {mqtt="<[mosquitto:D01R01Out:state:default]"} -
Sitemap configuration related to the issue
home.sitemap
sitemap Home label=“SmartHome”
Switch item=D01R01In label="Licht"
Text item=D01R01Out
At the mqtt.cfg I just edited the following line
mosquitto.url=tcp://localhost:1883
- If logs where generated please post these here using code fences:
Errors of openhab.log
2017-11-22 23:56:59.454 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.457 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.459 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.462 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.465 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.469 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.473 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:56:59.476 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:56:59.481 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:56:59.484 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:56:59.486 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01Out’ for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:56:59.489 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01Out’ for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:56:59.491 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01Out’ for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:57:00.157 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at ‘items/D01R01In’ for the unknown item ‘D01R01In’.
2017-11-22 23:57:00.823 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:57:00.827 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01In’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:57:00.830 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-22 23:57:00.835 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01Out’ for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:57:00.838 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘D01R01Out’ for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:57:00.843 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2017-11-22 23:57:01.524 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at ‘items/D01R01In’ for the unknown item ‘D01R01In’.
2017-11-22 23:57:02.275 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at ‘items/D01R01In’ for the unknown item ‘D01R01In’.
2017-11-22 23:57:03.030 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at ‘items/D01R01In’ for the unknown item ‘D01R01In’.
