(the item corresponds to a temperature sensor item I have set up).
Every minute I am logging the following message:
2021-12-30 16:38:00.466 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException: {"code":"unauthorized","message":"Unauthorized"}
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:175) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
I’ve verified that user names, passwords, database names all match between my .cfg and influxdb. I am hopefully missing something simple here?
Aslo running 3.2.0. Although mine is influx 1.0, I’m not using influxdb.cfg.
Instead it is configured through the Settings UI under Other Services, Influx Persistence Service.
Thanks for the suggestion @brianlay. I did check there and the .cfg file is simply populating the fields on that page. But I did notice that there was a selection for Version 1 or 2 of the db, and 1 was selected. I changed it to 2 and my every minute error message blew up! But perhaps that’s a clue? New error message below:
2021-12-31 12:24:01.508 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.UnauthorizedException: unauthorized access
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:98) ~[bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.toInfluxException(AbstractWriteClient.java:574) ~[bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.lambda$new$12(AbstractWriteClient.java:181) ~[bundleFile:?]
at io.reactivex.internal.subscribers.LambdaSubscriber.onNext(LambdaSubscriber.java:65) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableDoFinally$DoFinallySubscriber.onNext(FlowableDoFinally.java:84) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.drain(FlowableConcatMapMaybe.java:284) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.onNext(FlowableConcatMapMaybe.java:137) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.drain(FlowableConcatMapSingle.java:279) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.innerSuccess(FlowableConcatMapSingle.java:179) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber$ConcatMapSingleObserver.onSuccess(FlowableConcatMapSingle.java:317) [bundleFile:?]
at io.reactivex.internal.operators.single.SingleMap$MapSingleObserver.onSuccess(SingleMap.java:64) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableCollectSingle$CollectSubscriber.onComplete(FlowableCollectSingle.java:119) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableSubscriber.onComplete(BasicFuseableSubscriber.java:120) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableConditionalSubscriber.onComplete(BasicFuseableConditionalSubscriber.java:119) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.checkTerminated(FlowableGroupBy.java:686) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drainNormal(FlowableGroupBy.java:626) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drain(FlowableGroupBy.java:558) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.onComplete(FlowableGroupBy.java:548) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupedUnicast.onComplete(FlowableGroupBy.java:474) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupBySubscriber.onComplete(FlowableGroupBy.java:213) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.checkTerminated(UnicastProcessor.java:430) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drainRegular(UnicastProcessor.java:314) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drain(UnicastProcessor.java:397) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.onComplete(UnicastProcessor.java:487) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.drain(FlowableWindowBoundarySupplier.java:254) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.innerNext(FlowableWindowBoundarySupplier.java:166) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryInnerSubscriber.onNext(FlowableWindowBoundarySupplier.java:316) [bundleFile:?]
at io.reactivex.processors.PublishProcessor$PublishSubscription.onNext(PublishProcessor.java:360) [bundleFile:?]
at io.reactivex.processors.PublishProcessor.onNext(PublishProcessor.java:243) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$MergeSubscriber.tryEmit(FlowableFlatMap.java:282) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$InnerSubscriber.onNext(FlowableFlatMap.java:668) [bundleFile:?]
at io.reactivex.subscribers.SerializedSubscriber.onNext(SerializedSubscriber.java:100) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber.drainLoop(FlowableWindowTimed.java:498) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber$ConsumerIndexHolder.run(FlowableWindowTimed.java:579) [bundleFile:?]
at io.reactivex.Scheduler$Worker$PeriodicTask.run(Scheduler.java:479) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) [bundleFile:?]
Thanks, @brianlay. That helped me fix the issue. It wasn’t that the .cfg was functioning inappropriately necessarily, but I did not have the data buckets within Influxdb set up correctly to receive the data. Using the UI settings page I was able to walk down each of the settings and follow the guidance for each, and discover my gaps.
I’m still so used to using files for management as under OH 2 that I still don’t fully utilize the settings pages of OH 3. I was relying on the documentation page for Influx and it’s lacking. But the way that the settings page is set up, it’s really its own documentation.
