Hello!
I use an openhabian Image on a Rasperry Pi.
When I update the system to new OpenHAB Version 2.5.2 (latest) the connection to the cloud doesn’t work anymore. The Secret and the UUID are correct and myopenhab the system is “online” but there are no items and the dashboard is not reachable (Error 504).
I can not find any faults in my LOG File.
I already tried to reinstall the cloud connector, but nothing helps.
If so, that is correct. Items would only show up here if they had been exposed to myopenhab so that they’ll work with services such as IFTTT. However, that functionality was disabled last August, as it was causing myopenhab’s servers to crash frequently. So even if you expose items in PaperUI, they aren’t going to show up in this list.
I’m not sure why you’re getting the 504 error. If you haven’t already done so, multiple restarts are sometimes needed after updating OH to get everything back to full function.
What happens if you try to access OH using the Android or iOS app?
I’d suggest reverting to a backup and then trying the update again. I haven’t read of anyone else experiencing this issue with the 2.5.2 update, but perhaps someone with more expertise will chime in.
The bundle wasn’t even installed, as far as I could tell. OpenHAB thought it was installed, but it either wasn’t, or wasn’t being detected by the ESH framework.
I had to uninstall the connector, restart OpenHAB, and then reinstall it to get it working again.
