I have a problem regarding a handheld transmitter from Homematic. The HM Binding is correctly configured and some other actuators and sensors are working fine.
When i press the handheld there is no update of the item in the openHAB event bus. But the update is shown in WEBUI of HM, showing the communication between HM and the Handheld is working fine. If i manually trigger the handheld in the HM WEBUI the event bus shows : “HMHandsender_1_Rechts changed from ON to OFF” , just like it should. anybody experienced sth similar ?
