Hi All,
Yesterday I upgraded to the latest 2.2 release of OpenHab. It’s working fine. PaperUI, sensors, all is working. But today I want to play around a little bit and I figured out that there is no “log” command in the Karaf console anymore. After the login I get:
[alarm@alarmpi ~]$ ssh openhab@127.0.0.1 -p 8101
Password authentication
Password:
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.2.0
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
but
openhab> help log
COMMANDS
openhab> log:tail
Command not found: log:tail
Do i miss something? The file logger is working but it’s not really useful for some live debugging.
Before the upgrade I used the snapshot 1083 of openhab 2.2 and logging was working fine. But then I just replaced the snapshot package by the 2.2 release package. I’m using Arch Linux on a Raspberry Pi 3 and I build the install packages by myself. Maybe a clean install is needed?
Hmm… Hi @lgt - I have 2.2.0-1 and I do have log commands in my console (Altho admittedly it did take me ages to get onto the console).
In some of the snapshots though I had similar issues. But in the release, the logs in the console is one thing that does work for me.
hamish@piman-202:~$ ssh -p 8101 openhab@localhost
Password:
__ _____ ____
/_/ 2.2.0
Release Build
openhab> help log
SUBSHELL
log
COMMANDS
log:clear Clear log entries.
log:display Displays log entries.
log:exception-display Displays the last occurred exception from the log.
log:get Shows the currently set log level.
log:load-test Load test log.
log:log Log a message.
log:set Sets the log level.
log:tail Continuously display log entries. Use ctrl-c to quit this command
openhab> ```
The inconsistency does worry me. I've got issues that others don't have (users.properties being missing initially) and continual errors from the REST interface about Jersey (Whoever the heck that is) not being ready...
Not until now. I’m using Arch Linux and I’m just upgraded the 2.2 snapshot package with the 2.2 release package. I think I should do a clean install after the holidays.
