No more log after upgrade
Hello, I’m running Openhab 2.2 on Windows 10 x64. Everything works fine except my log file, which is now called wrapper.log (using the service wrapper since 2.1) now contain way less stuff then before.
I use in rules many loginfo to log what’s going on, like:
logInfo(“WEMO”, “Turning on outdoor front light - trigger from garage door”)
Now, these line doesn’t appear anymore in my log. I do have many INFO logged, but those from my rules doesn’t appear. I also tried creating custom log explicitly for these but nothing worked. This happened since I upgraded from 2.1 to 2.2.
Thank you!
Ok, I just found out that the file org.ops4j.pax.logging.cfg changed since 2.1 to 2.2, it’s now using the same package, thus all configuration does nothing. I think you should update the information on the upgrade page because it says not to replace any existing file.
Is there other file I should modify/replace that wasn’t replace in userdata while doing the upgrade?
Thank you
In general it’s correct not to change existing files.
Swapping to log4j2 was marked as breaking change in changelogs and there are lots of discussions in this forum regarding this special point.
