I’ve got an older YRD220 lock which I believe implements an older version of COMMAND_CLASS_ALARM so I get the raw json events in the style below, and it works fine.
{"type":"22","value":"1"}
I’ve got a newer YRD256 lock which I believe implements a newer COMMAND_CLASS_ALARM (v4?) so I get raw json events in this style:
{"notification":"ACCESS_CONTROL__MANUAL_UNLOCK","level":"1","type":"ACCESS_CONTROL","event":"2","status":"255"}
These mostly work, but not all.
It seems that all the events with notification type 0x06 (which I guess are the ACCESS_CONTROL ones) work fine, but the low battery alarms use notification type 0x08, as does the “RF module power cycled” event. (reading the doco here https://opensmarthouse.org/zwavedatabase/594/reference/Yale-Real-Living-ZWave-Plus-System-Integrators-Guide-YRL-deadbolts-Rev-4.pdf)
I can see the events that don’t work likely map to these POWER_MANAGEMENT constants in the code - so there is code for this - so presumably they are supported by the binding?
(the event number in the doco matches the code)
When I try and cause the YRD256 to send one of these events (ie I remove and replace the battery which should send POWER_MANAGEMENT__MAINS_APPLIED), nothing appears in the debug logs at all - no exception or warning or anything to suggest a bug in the code, or even that the lock has sent any data at all. In contrast, the YRD220 gives me the expected raw json string when I remove and replace the battery.
So my question is:
a) does anyone else get POWER_MANAGEMENT events from their Yale/Assa Abloy lock with the newer z-wave chip (eg the YRD256 with the ZWM-1 module)? @ae_0017 I saw you mention in another thread that you have this lock - does it work for you? And @5iver have you got this one - any thoughts?
b) @chris the fact that I see absolutely nothing in the debug logs - does that mean for definite that the lock isn’t sending anything? So potentially I have a faulty lock, or my z-stick (aeon gen5) doesn’t fully support this notification type in the newer COMMAND_CLASS_ALARM? Or would the binding not be logging the message as it doesn’t understand it at some low level?
I’m using OH2. Thanks in advance for any advice from anyone!
