Trying to setup an IDE following the procedure described here
http://docs.openhab.org/developers/development/ide.html
The procedure works fine, except that the resource files are not installed.
Anyone a suggestion?
2 weeks later I retried the installation, with succes.
The difference: I installed in a different order:
- Oracle JDK
- Git
- Maven
I set the JAVA_HOME environment variable, and added the maven bin to the path, as described here:
https://maven.apache.org/install.html
And then the Eclipse intaller
