I have at this moment about 15 sonoffs with tasmota running on a openhab system (both habpanel and basicui, sitemap).
After some initial problems everything works as expected, in habpanel I have some (self)made web-pages running to display pictures, webradio, processor-temperature en fancontrol.
But… I have a problem: there is no feedback from the devices to habpanel or the sitemap.
A part of my config:
Mosquitto responds correct but habpanel does not respond (if I switch the light on trough the sitemap the light switches on like expected but when I switch the light off trought the button on the sonoff the sitemap or habpanel does not update)
Mosqutto log:
mosquitto_sub -t “#” -v|grep tl
cmnd/sonoff_keuken_tl/POWER1 1 <-- Habpanel action
cmnd/sonoff_tl/POWER1 ON
stat/sonoff_tl/RESULT {“POWER”:“ON”}
stat/sonoff_tl/POWER ON
cmnd/sonoff_tl/POWER OFF <-- Habpanel action
stat/sonoff_tl/RESULT {“POWER”:“OFF”}
stat/sonoff_tl/POWER OFF
Updating the basicUI or other is real-time is an issue that does not work for everyone for quite a long time. A manual refresh helps in all cases, however is admittedly unsatisfactory.
This far this effect has been very difficult to reproduce and hence is unresolved.
I have my sonoff devices working as expected, however without any thing definition at all(neither PaperUi nor file).
Since MQTT Action and Binding are both OH1 versions, I see no reason for the need of a thing!
