Hi, I’ve run out of ideas. I have OH 2.5 running using the powermax alarm binding connecting to my alarm over serial port working perfectly…
I’ve made an implace upgrade to OH3 and everything is working but the powemax keeps yielding the “No such device /dev/ttyUSB0” error after upgrade.
I’ve double checked all info related to this problem I’ve found in the forums, but to no avail.
I have de gnu.io.rxtx.SerialPort option properly set (here is my ps output of openhab comand)
openhab 2487223 1 7 23:13 ? 00:01:19 /usr/bin/java -XX:-UsePerfData
-Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab
-Dopenhab.runtime=/usr/share/openhab/runtime
-Dopenhab.userdata=/var/lib/openhab
-Dopenhab.logdir=/var/log/openhab
-Dfelix.cm.dir=/var/lib/openhab/config
-Djava.library.path=/var/lib/openhab/tmp/lib
-Djetty.host=192.168.4.248
-Djetty.http.compliance=RFC2616
-Dnashorn.args=--no-deprecation-warning
-Dorg.apache.cxf.osgi.http.transport.disable=true
-Dorg.ops4j.pax.web.listening.addresses=192.168.4.248
-Dorg.osgi.service.http.port=8090
-Dorg.osgi.service.http.port.secure=8444
-Djava.awt.headless=true
-Dfile.encoding=UTF-8
-XX:+UseG1GC
**-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0**
--add-reads=java.xml=java.logging
--add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAMED
--patch-module java.base=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.3.7.jar --patch-module java.xml=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.3.7.jar
--add-opens java.base/java.security=ALL-UNNAMED
--add-opens java.base/java.net=ALL-UNNAMED
--add-opens java.base/java.lang=ALL-UNNAMED
--add-opens java.base/java.util=ALL-UNNAMED -
-add-opens java.naming/javax.naming.spi=ALL-UNNAMED
--add-opens java.rmi/sun.rmi.transport.tcp=ALL-UNNAMED
--add-opens java.base/java.io=ALL-UNNAMED
--add-opens java.base/java.lang.reflect=ALL-UNNAMED -
-add-opens java.base/java.text=ALL-UNNAMED
--add-opens java.base/java.time=ALL-UNNAMED
--add-opens java.desktop/java.awt.font=ALL-UNNAMED
--add-exports=java.base/sun.net.www.protocol.file=ALL-UNNAMED -
-add-exports=java.base/sun.net.www.protocol.ftp=ALL-UNNAMED
--add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED
--add-exports=java.base/sun.net.www.protocol.https=ALL-UNNAMED
--add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED
--add-exports=java.base/sun.net.www.content.text=ALL-UNNAMED
--add-exports=jdk.xml.dom/org.w3c.dom.html=ALL-UNNAMED
--add-exports=jdk.naming.rmi/com.sun.jndi.url.rmi=ALL-UNNAMED
--add-exports=java.rmi/sun.rmi.registry=ALL-UNNAMED
--add-exports=java.security.sasl/com.sun.security.sasl=ALL-UNNAMED
-Dkaraf.instances=/var/lib/openhab/tmp/instances
-Dkaraf.home=/usr/share/openhab/runtime
-Dkaraf.base=/var/lib/openhab -Dkaraf.data=/var/lib/openhab -Dkaraf.etc=/var/lib/openhab/etc -Dkaraf.log=/var/log/openhab -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab/tmp -Djava.util.logging.config.file=/var/lib/openhab/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.main-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/osgi.core-7.0.0.jar:/usr/share/openhab/runtime/lib/jdk9plus/istack-commons-runtime-3.0.10.jar:/usr/share/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.2.jar:/usr/share/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:/usr/share/openhab/runtime/lib/jdk9plus/txw2-2.3.3.jar org.apache.karaf.main.Main
openhab user is in my dialout group and in my tty group
(sorry, command output in spanish but translated means User openhab already member of …)
root@Molinos4:/home/chano# adduser openhab dialout
El usuario `openhab' ya es un miembro de `dialout'.
root@Molinos4:/home/chano# adduser openhab tty
El usuario `openhab' ya es un miembro de `tty'.
I’m running openhab native (no docker) on debian 11
Any idea??
Thx in advance
