No suitable driver found for jdbc:mysql//ocalhost:3306/openhab
I’ve got openHAB running after installing (installed everything using apt-get).
Followed instructions at https://github.com/openhab/openhab/wiki/Ubuntu-on-x64 for installing, particularly mysql.
I now get the No suitable driver found error in the logs.
I’ve tried 127.0.0.1, localhost… with and without :3306…
11:29:22.399 [ERROR] [.p.m.i.MysqlPersistenceService:509 ] - mySQL: Failed connecting to the SQL database using: driverClass=com.mysql.jdbc.Driver, url=jdbc:mysql//localhost:3306/openhab, user=openhab, password=openhab
java.sql.SQLException: No suitable driver found for jdbc:mysql//localhost:3306/openhab
at java.sql.DriverManager.getConnection(DriverManager.java:689) ~[na:1.8.0_74]
at java.sql.DriverManager.getConnection(DriverManager.java:247) ~[na:1.8.0_74]
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.connectToDatabase(MysqlPersistenceService.java:477) [bundlefile:na]
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.activate(MysqlPersistenceService.java:179) [bundlefile:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_74]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_74]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_74]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_74]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
Thanks very much in advance!
J.F.
It looks like you are missing a : in your JDBC URL. Have a look at this wiki page:
Looks like you da man!
Thanks Watoo!
