No vertical alignment possible in f7-list
Hi all,
I observe a strange behaviour. I made a little widget for some room conditions.
In the widget editor, the preview works perfectly. It is about vertical alignment of the f7-row inside the f7-list-item.
The issue can be seen if I increase the f7-list-item-min-height (for demonstration purpose to 100px). The expected behaviour is: the content is vertically aligned inside the list item.
This works for the editor preview, but when using this widget in the fixed canvas environment, the vertical alignment is ignored. (You can see this on the screenshots attached).
I tried a lot with “align-items: center” and stylesheets for all elements (f7-card, f7-list, f7-row, f7-list-item). Everything is well ignored.
The development tools tells me:
This element is a flex item, i.e. a child of a flex container, but align-items only applies to containers.
Try setting the align-items on the container element or use align-self instead.
Any idea how to fix is? I can work around this with height and paddings, but that’s not the preferred solution.
Thank you!
Jan
uid: Raumtemperatur_backup
tags: []
props:
  parameters: []
  parameterGroups: []
timestamp: Jan 2, 2025, 3:58:43 PM
component: f7-card
  title: Raumtemperatur
slots:
  default:
    - component: f7-list
        style:
          --f7-list-font-size: 16px
          --f7-list-item-min-height: 100px
      slots:
        default:
          - component: f7-list-item
              style:
                box-shadow: none
                margin-left: 0
                margin-right: 0
                --f7-list-item-padding-vertical: 0px
                background: '=(Number.parseFloat(items.ShellyHTSauna_Luftfeuchtigkeit.state) >
                  60 ) ? "#FF8585" : ""'
              stylesheet: |
                .item-inner {
                  display: inline-block;
            slots:
              inner-start:
                - component: f7-row
                    style:
                      justify-content: space-between
                      align-items: center
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: left
                          width: 25
                        slots:
                          default:
                            - component: oh-icon
                                style:
                                  vertical-align: middle
                                icon: bedroom
                                width: 30
                      - component: f7-col
                          style:
                            text-align: right
                          width: 40
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                                  justify-content: flex-start
                              slots:
                                default:
                                      style:
                                      icon: temperature
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =items.ShellyHTSauna_Temperatur.state
                      - component: f7-col
                          style:
                            text-align: right
                          width: 35
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                                  justify-content: flex-end
                              slots:
                                default:
                                      style:
                                      icon: humidity
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =Math.round(Number.parseFloat(items.ShellyHTSauna_Luftfeuchtigkeit.state))+
              style:
                box-shadow: none
                margin-left: 0
                margin-right: 0
                background: '=(Number.parseFloat(items.ShellyHTBad_Luftfeuchtigkeit.state) > 60
                  ) ? "#FF8585" : ""'
              stylesheet: |
                .item-inner {
            slots:
              inner-start:
                - component: f7-row
                    style:
                      align-items: center
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: left
                          width: 25
                        slots:
                          default:
                                style:
                                icon: bath
                                width: 30
                      - component: f7-col
                          style:
                            text-align: right
                          width: 40
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                              slots:
                                default:
                                      style:
                                      icon: temperature
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =items.ShellyHTBad_Temperatur.state
                      - component: f7-col
                          style:
                            text-align: right
                          width: 35
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                              slots:
                                default:
                                      style:
                                      icon: humidity
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =Math.round(Number.parseFloat(items.ShellyHTBad_Luftfeuchtigkeit.state))
              style:
                box-shadow: none
                margin-left: 0
                margin-right: 0
                background: '=(Number.parseFloat(items.Shelly_HT_HWR_Luftfeuchtigkeit.state) >
              stylesheet: |
                .item-inner {
            slots:
              inner-start:
                - component: f7-row
                    style:
                      align-items: center
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: left
                          width: 25
                        slots:
                          default:
                                style:
                                icon: cellar
                                width: 30
                      - component: f7-col
                          style:
                            text-align: right
                          width: 40
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                              slots:
                                default:
                                      style:
                                      icon: temperature
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =items.Shelly_HT_HWR_Temperatur.state
                      - component: f7-col
                          style:
                            text-align: right
                          width: 35
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  align-items: center
                              slots:
                                default:
                                      style:
                                      icon: humidity
                                      width: 16
                                  - component: Label
                                      style:
                                        margin-left: 5px
                                      text: =Math.round(Number.parseFloat(items.Shelly_HT_HWR_Luftfeuchtigkeit.state))
No_vertical_alignment
Vertical_alignment_editor
I don’t use the fixed canvas layout, but it looks like the difference is the row height. The widget editor does have a .row {height: 100%} directive which it appears the canvas layout doesn’t have so just make each of your rows:
                - component: f7-row
                    style:
                      height: 100%
                      align-items: center
Thank you very much! Very easy fix but hard to see (for me :rofl:)
