Hello Community
I’ve tried to update from my OH 2.0 to OH 2.1 stable.
My environment:
- Physical Server with Ubuntu 16.04 LTS
- repository installation of OH 2
- AEON Stick Gen5 Controller
- 100 zWave Devices
I did an apt-get update and apt-get upgrade and updated to OH 2.1
Everything looked fine. My controller went up and I saw the usual initiallation communication.
But no device communicate (receive commands, send status updates e.g.).
I checked the userrights, the Port-Config, my Java Settings… but nothing was wrong.
I deceided to switch back to OH2 (from backup as descriped in the docs) the same error occurs.
I let the system time for more than 4 hours. Now, all initializings are done. An no communication.
When I activate the DEBUG Log I receive this messages for many devices:
21:59:36.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Polling...
21:59:36.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Polling zwave:device:215577f7:node21:switch_binary
21:59:36.508 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Polling aborted as no converter found for zwave:device:215577f7:node21:switch_binary
At a try to send a command manually the log shows tis:
Item:
Dimmer EG_Wohnen_DIM_Licht_2 "Spots [%.0f %%]" <dimmablelight> (gEG_Wohnen, gDimmers, gLights) {channel="zwave:device:xxx:node38:switch_dimmer"}
22:07:39.454 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EG_Wohnen_DIM_Licht_2' received command 25
22:07:39.456 [INFO ] [ome.event.GroupItemStateChangedEvent] - gDimmers changed from 0 to UNDEF through EG_Wohnen_DIM_Licht_2
22:07:39.458 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_Wohnen_DIM_Licht_2 changed from 0 to 25
22:07:39.704 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=GetRoutingInfo[0x80], type=Request[0x00], priority=High, dest=255, callback=0, payload=22 00 00 03
22:07:39.704 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 486
22:07:39.704 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 80 26 00 00 03 5D
22:07:39.705 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 07 00 80 26 00 00 03 5D
22:07:44.705 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
22:07:44.705 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 487. Queue={}
22:07:44.705 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 486
22:07:44.706 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 80 26 00 00 03 5D
22:07:44.706 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 07 00 80 26 00 00 03 5D
22:07:46.823 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 61 0A 32 02 21 34 00 00 00 00 00 00 A5
22:07:46.824 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
22:07:46.825 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 61 0A 32 02 21 34 00 00 00 00 00 00 A5
22:07:46.825 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 61 0A 32 02 21 34 00 00 00 00 00 00 A5
22:07:46.826 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 61 0A 32 02 21 34 00 00 00 00 00 00
22:07:46.826 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 97: Application Command Request (ALIVE:DONE)
22:07:46.826 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 97: Starting initialisation from DONE
22:07:46.826 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1a0953c2 already registered
22:07:46.826 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 97: Incoming command class METER
22:07:46.826 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 97: Received METER command V3
22:07:46.826 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 97: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
22:07:46.827 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
22:07:46.827 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 97: Got an event from Z-Wave network: ZWaveMeterValueEvent
22:07:46.827 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 97: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0E+1
22:07:46.827 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 72: Transaction not completed: node address inconsistent. lastSent=72, incoming=255
Do you have any ideas to fix it?
What further information do you may need?
Michael
