NoClassDefFound on ThingHandlerFactory
Hi, I have been developping a binding for merossIOT. The bundle archetype runs properly.
Then I add following binding pom file:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://maven.apache.org/POM/4.0.0"
  xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <parent>
    <groupId>org.openhab.addons.bundles</groupId>
    <artifactId>org.openhab.addons.reactor.bundles</artifactId>
    <version>4.3.0-SNAPSHOT</version>
  </parent>
  <artifactId>org.openhab.binding.meross</artifactId>
  <name>openHAB Add-ons :: Bundles :: Meross Binding</name>
  <build>
    <plugins>
      <plugin>
        <groupId>org.apache.felix</groupId>
        <artifactId>maven-bundle-plugin</artifactId>
        <version>5.1.9</version>
        <executions>
          <execution>
            <id>bundle-manifest</id>
            <phase>process-classes</phase>
            <goals>
              <goal>manifest</goal>
            </goals>
          </execution>
        </executions>
        <extensions>true</extensions>
        <configuration>
          <instructions>
            <Bundle-SymbolicName>${project.artifactId}</Bundle-SymbolicName>
            <Import-Package>org.meross4j.*</Import-Package>
            <Embed-Transitive>true</Embed-Transitive>
            <Bundle-Version>$(replace;$(project.version);"").$(tstamp;yyyyMMdd-HHmm)</Bundle-Version>
          </instructions>
        </configuration>
      </plugin>
    </plugins>
  </build>
  <dependencies>
    <dependency>
      <groupId>org.meross4j</groupId>
      <artifactId>meross4j</artifactId>
      <version>0.2.8</version>
    </dependency>
  </dependencies>
</project>
As you can see I have a dependency on meross4j, so I do a Import-Package istruction on that, together with Embed-Transitive.
Here is the meross4j library pom file:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <name>meross4j Meross Java library</name>
    <description>meross4j is a Java library for the Meross cloud</description>
    <distributionManagement>
        <repository>
            <id>github</id>
            <name>GitHub Packages</name>
            <url>https://maven.pkg.github.com/fabgio/meross4j</url>
        </repository>
    </distributionManagement>
    <licenses>
        <license>
            <name>Eclipse Public License 2.0</name>
            <url>https://www.eclipse.org/legal/epl-2.0</url>
            <distribution>repo</distribution>
        </license>
    </licenses>
    <developers>
        <developer>
            <id>fabgio</id>
            <name>Giovanni Fabiani</name>
            <roles>
                <role>developer</role>
            </roles>
            <timezone>Europe/Rome</timezone>
        </developer>
    </developers>
    <properties>
        <maven.compiler.source>17</maven.compiler.source>
        <maven.compiler.target>17</maven.compiler.target>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    </properties>
    <dependencies>
        <dependency>
            <groupId>org.junit.jupiter</groupId>
            <artifactId>junit-jupiter-engine</artifactId>
            <version>5.10.2</version>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>com.google.code.gson</groupId>
            <artifactId>gson</artifactId>
            <version>2.10.1</version>
        </dependency>
        <dependency>
            <groupId>org.apache.logging.log4j</groupId>
            <artifactId>log4j-slf4j-impl</artifactId>
            <version>2.23.1</version>
        </dependency>
        <dependency>
            <groupId>com.hivemq</groupId>
            <artifactId>hivemq-mqtt-client</artifactId>
            <version>1.3.3</version>
        </dependency>
        <dependency>
            <groupId>org.osgi</groupId>
            <artifactId>org.osgi.core</artifactId>
            <version>6.0.0</version>
        </dependency>
    </dependencies>
    <repositories>
        <repository>
            <id>maven_central</id>
            <name>Maven Central</name>
            <url>https://repo.maven.apache.org/maven2/</url>
        </repository>
        </repositories>
    <build>
        <plugins>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <artifactId>maven-source-plugin</artifactId>
                <version>3.3.0</version>
                <executions>
                    <execution>
                        <id>attach-sources</id>
                        <phase>verify</phase>
                        <goals>
                            <goal>jar-no-fork</goal>
                        </goals>
                    </execution>
                </executions>
            </plugin>
            <plugin>
                <artifactId>maven-javadoc-plugin</artifactId>
                <version>3.6.3</version>
                <configuration>
                    <javadocExecutable>${java.home}/bin/javadoc</javadocExecutable>
                    <release>17</release>
                </configuration>
                <executions>
                    <execution>
                        <id>attach-javadocs</id>
                        <goals>
                            <goal>jar</goal>
                        </goals>
                    </execution>
                </executions>
            </plugin>
            <plugin>
            <artifactId>maven-jar-plugin</artifactId>
            <configuration>
                <archive>
                    <manifestFile>${project.build.outputDirectory}/META-INF/MANIFEST.MF</manifestFile>
                </archive>
            </configuration>
            </plugin>
            <plugin>
                <executions>
                    <execution>
                        <goals>
                        </goals>
                    </execution>
                </executions>
                <configuration>
                    <instructions>
                        <Bundle-Activator>org.meross4j.bundle.Activator</Bundle-Activator>
                        <Export-Package>org.meross4j.*</Export-Package>
                    </instructions>
                </configuration>
            </plugin>
        </plugins>
    </build>
    </project>
Here is the output of karaf’s bundle:headers command
openHAB Add-ons :: Bundles :: Meross Binding (285)
Automatic-Module-Name = org.openhab.binding.meross
Bnd-LastModified = 1730133945046
Build-Jdk-Spec = 17
Created-By = Apache Maven Bundle Plugin 5.1.9
Embed-Transitive = true
Manifest-Version = 1.0
Originally-Created-By = 17.0.13 (Azul Systems, Inc.)
Service-Component = OSGI-INF/org.openhab.binding.meross.internal.MerossHandlerFactory.xml,OSGI-INF/org.openhab.binding.meross.internal.MerossHandlerFactory.xml
Tool = Bnd-6.3.1.202206071316
Bundle-Description = This project contains the official add-ons of openHAB
Bundle-Developers = openhab;email="info@openhab.org";name=openHAB;organization=openHAB;organizationUrl="https://www.openHAB.org"
Bundle-DocURL = https://www.openhab.org
Bundle-License = https://www.eclipse.org/legal/epl-2.0/
Bundle-ManifestVersion = 2
Bundle-Name = openHAB Add-ons :: Bundles :: Meross Binding
Bundle-SCM = url="https://github.com/openhab/openhab-addons/org.openhab.addons.reactor.bundles/org.openhab.binding.meross",connection="scm:git:https://github.com/openhab/openhab-addons.git/org.openhab.addons.reactor.bundles/org.openhab.binding.meross",developer-connection="scm:git:https://github.com/openhab/openhab-addons.git/org.openhab.addons.reactor.bundles/org.openhab.binding.meross",tag=HEAD
Bundle-SymbolicName = org.openhab.binding.meross
Bundle-Vendor = openHAB.org
Bundle-Version = 4.3.0.SNAPSHOT20241028-1645
Provide-Capability =
        osgi.service;
                uses:=org.openhab.core.thing.binding;
                objectClass:List<String>=org.openhab.core.thing.binding.ThingHandlerFactory
Require-Capability =
        osgi.extender;filter:=(&(osgi.extender=osgi.component)(version>=1.5.0)(!(version>=2.0.0))),
        osgi.ee;filter:=(&(osgi.ee=JavaSE)(version=17)),
Export-Package =
        org.meross4j.bundle;version=0.2.8,
        org.meross4j.command;version=0.2.8,
        org.meross4j.communication;uses:=org.meross4j.record;version=0.2.8,
        org.meross4j.factory;uses:=org.meross4j.command;version=0.2.8,
        org.meross4j.util;version=0.2.8
Import-Package =
        org.meross4j.command;version="[0.2,1)",
        org.meross4j.communication;version="[0.2,1)",
        org.meross4j.factory;version="[0.2,1)",
        org.meross4j.record;version="[0.2,1)",
        org.meross4j.util;version="[0.2,1)"
Karaf shows the binding is active
Then when the Handler starts I have got a NoClassDefFound on ThingHandlerFactory class; clearly meaning that one dependency the class depends on is missing (OSGi in action book); so obviously the HandlerFactory service cannot start! How can I make ThingHanderFactory service visible again?
