Hi All
Ive got this visible in PaperUI, the mechnical button on the Relay switches the load on and off, and the toggle switch works just fine too
I cannot though switch the light on/off using ZWave.
The XML appears valid, and changes to the Node are reflected OK. I couldnt see an issue in the zwave log]
Here are the details:
And my items file
/*ZWave Switch Node 11 BBQ/Tree Lights*/
Switch Node11Sw1 "Node 11 Sw1" (gLights_Random,gAllLights,gOutsideLights) { channel="zwave:device:ce741a7c:node11:switch_binary1" }
Switch Node11Sw2 "Node 11 Sw2" (gLights_Random,gAllLights,gOutsideLights) { channel="zwave:device:ce741a7c:node11:switch_binary2" }
Number Node11Num1 "Node 11 Sw1 - Current Consumption [%.1f W]" (gAllLightsUsage,gEnergyRealTime) { channel="zwave:device:ce741a7c:node11:meter_watts1" }
Number Node11Num2 "Node 11 Sw1 - Usage [%.1f kW]" (gPowerUsage) { channel="zwave:device:ce741a7c:node11:meter_kwh1" }
Number Node11Num3 "Node 11 Sw2 - Current Consumption [%.1f W]" (gAllLightsUsage,gEnergyRealTime) { channel="zwave:device:ce741a7c:node11:meter_watts2" }
Number Node11Num4 "Node 11 Sw2 - Usage [%.1f kW]" (gPowerUsage) { channel="zwave:device:ce741a7c:node11:meter_kwh2" }
There are 6 active channels in Habmin, but I cant get the darn thing to turn off. I notice that node 11 doesnt have any neighbors but the controller, where as Node 10 (working) and literally 2cm away from Node 11 has 5 neighbors.
Any suggestions?
