Node-RED as Alternative Rule Engine
Sorry I thought it was possible to send a new value as state !
You said you have an update with MQTT, can you post more detail?
I’m also struggling to get the openhab controllers to work.
@chrisaddams Unfortunately I don’t use OpenHab anymore so can’t give you a detailed walk through.
What I did was install Mosquitto as a MQTT broker, then use the MQTT plugin for OpenHab to subscribe / publish to Mosquitto, then from the Node-Red side I just setup MQTT input/output nodes to connect to my control logic. From a topic perspective, my strategy is to use /room/item as an update topic and /room/item/set as a control topic from the controller to the MQTT broker
Here is an example of the Node-Red side since I still use MQTT between it and HomeSeer to accomplish a similar architecture:
Hope that helps.
Hi can you post a small code exmpale?
for when two things are on make it on?
Good evening sorry I didn’t reply on the post.
I finally got it working using the following:
I needed to specify the Topic on the “openhab2-out” item.
Hey @Gad_Ofir sorry I forgot about your Question. Also I was not sure if you really meant me :smiley:
But yea ofc here you go
[{"id":"fb9fcdff.a58b28","type":"and-gate","z":"314172e3.35fde6","name":"","rules":[{"t":"eq","v":"OFF","vt":"str","propertyType":"msg","property":"payload","topic":"doorOFF"},{"t":"eq","v":"OFF","vt":"str","propertyType":"msg","property":"payload","topic":"movOFF"}],"outputTopic":"result","gateType":"and","emitOnlyIfTrue":true,"x":887,"y":219,"wires":[["35bc86d0.b4c72a"]]},{"id":"4ad3560.432b22c","type":"change","z":"314172e3.35fde6","name":"OPEN=ON CLOSED=OFF","rules":[{"t":"change","p":"payload","pt":"msg","from":"OPEN","fromt":"str","to":"ON","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"CLOSED","fromt":"str","to":"OFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":465.5,"y":177,"wires":[["f2aadd6.0c8fc2","1c73b4f1.229643"]]},{"id":"42760df4.a8602c","type":"inject","z":"314172e3.35fde6","name":"","topic":"","payload":"CLOSED","payloadType":"str","repeat":"","crontab":"","once":false,"x":194,"y":163,"wires":[["4ad3560.432b22c"]]},{"id":"f2aadd6.0c8fc2","type":"change","z":"314172e3.35fde6","name":"doorOFF","rules":[{"t":"set","p":"topic","pt":"msg","to":"doorOFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":704.5,"y":190,"wires":[["fb9fcdff.a58b28"]]},{"id":"b48ee4e1.bf7868","type":"inject","z":"314172e3.35fde6","name":"","topic":"","payload":"ON","payloadType":"str","repeat":"","crontab":"","once":false,"x":156,"y":360,"wires":[["4b76cba5.4dbee4"]]},{"id":"93fe83d4.32afc8","type":"inject","z":"314172e3.35fde6","name":"","topic":"","payload":"OFF","payloadType":"str","repeat":"","crontab":"","once":false,"x":165,"y":400,"wires":[["4f854e12.4d6618"]]},{"id":"4f854e12.4d6618","type":"change","z":"314172e3.35fde6","name":"movOFF","rules":[{"t":"set","p":"topic","pt":"msg","to":"movOFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":718,"y":262,"wires":[["fb9fcdff.a58b28"]]},{"id":"35bc86d0.b4c72a","type":"debug","z":"314172e3.35fde6","name":"","active":false,"console":"false","complete":"true","x":1062,"y":175,"wires":[]},{"id":"cf1b8931.c43b88","type":"inject","z":"314172e3.35fde6","name":"","topic":"","payload":"OPEN","payloadType":"str","repeat":"","crontab":"","once":false,"x":197,"y":203,"wires":[["4ad3560.432b22c","1c73b4f1.229643"]]},{"id":"82808ca0.006ee8","type":"or-gate","z":"314172e3.35fde6","name":"","rules":[{"t":"eq","v":"ON","vt":"str","propertyType":"msg","property":"payload","topic":"doorON"},{"t":"eq","v":"ON","vt":"str","propertyType":"msg","property":"payload","topic":"movON"}],"outputTopic":"result1","gateType":"or","emitOnlyIfTrue":true,"x":889,"y":369,"wires":[["798dcb4a.193dec"]]},{"id":"1c73b4f1.229643","type":"change","z":"314172e3.35fde6","name":"doorON","rules":[{"t":"set","p":"topic","pt":"msg","to":"doorON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":343,"wires":[["82808ca0.006ee8"]]},{"id":"4b76cba5.4dbee4","type":"change","z":"314172e3.35fde6","name":"movON","rules":[{"t":"set","p":"topic","pt":"msg","to":"movON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":716,"y":390,"wires":[["82808ca0.006ee8"]]},{"id":"798dcb4a.193dec","type":"debug","z":"314172e3.35fde6","name":"","active":false,"console":"false","complete":"false","x":1070,"y":309,"wires":[]}]
You can import this to node-red. I changed a bit for testing and understanding
i suck at gates i guess becuse i did not undertsand a thing :slight_smile:
I can work on a better example to understand the functionality. I am on it :smiley: give me 20 minutes
Okay I hope this will help you understanding the logic gates :slight_smile:
Logic Gate Addon
Here is the code to paste this flow so you can try and error yourself :slight_smile:
The White boxes contain more information. Copy below or via pastebin https://pastebin.com/BLYGFn1Q
        "id": "3cac3927.abaf16",
        "type": "inject",
        "z": "127fd315.6c04dd",
        "name": "",
        "topic": "",
        "payload": "OPEN",
        "payloadType": "str",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 165.5,
        "y": 176,
        "wires": [
                "4d2ba3b8.29ec84",
                "72652330.3a11ac",
                "6da9c580.db005c"
        "id": "25fb8c64.060d0c",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "CLOSED",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 158,
        "y": 208,
        "wires": [
                "4d2ba3b8.29ec84",
                "72652330.3a11ac",
                "6da9c580.db005c"
        "id": "bda906de.dfdf78",
        "type": "comment",
        "name": "Item Door",
        "info": "This block displays a Door item from openHAB with the status OPEN/CLOSED",
        "x": 154.5,
        "y": 145,
        "wires": []
        "id": "6d8cfd0d.a20944",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "ON",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 170,
        "y": 409,
        "wires": [
                "c7d3f01.b3cba1",
                "5fd52631.fe9be8",
                "b69b8cef.4fec58"
        "id": "3a25038.87822fc",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "OFF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 171.5,
        "y": 441,
        "wires": [
                "c7d3f01.b3cba1",
                "5fd52631.fe9be8",
                "b69b8cef.4fec58"
        "id": "cf9b9b63.27f8e",
        "type": "comment",
        "name": "Item Movement Detection",
        "info": "This block displays a movment detection from openHAB\nwith the states ON/OFF",
        "x": 115,
        "y": 378,
        "wires": []
        "id": "78014ba9.80a13c",
        "type": "comment",
        "name": "Logic Gate Info",
        "info": "I used this \"Addon\"\nhttps://flows.nodered.org/node/node-red-contrib-bool-gate",
        "x": 667.5,
        "y": 612,
        "wires": []
        "id": "4a8849d1.f8a308",
        "type": "comment",
        "name": "openHAB INFO",
        "info": "so far as I have noticed, openHAB items do not\npublish a topic so we need to \"inject a topic ourself\"\n",
        "x": 666.5,
        "y": 580,
        "wires": []
        "id": "a9865891.288bd",
        "type": "change",
        "name": "topic=mov",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "mov",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 555,
        "y": 443,
        "wires": [
                "e36cea52.be3638",
                "f21e0fc0.db63e8",
                "efbc1126.53ca4"
        "id": "cbc9801c.5635e8",
        "type": "change",
        "name": "topic=door",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "door",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 590,
        "y": 202,
        "wires": [
                "2cda8f2f.a5bb98",
                "a5c3cc89.843c78",
                "f2afec2d.eb6ca"
        "id": "4d2ba3b8.29ec84",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "complete": "false",
        "x": 348.5,
        "y": 97,
        "wires": []
        "id": "72652330.3a11ac",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "complete": "topic",
        "x": 338,
        "y": 130,
        "wires": []
        "id": "2cda8f2f.a5bb98",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 850,
        "y": 112,
        "wires": []
        "id": "a5c3cc89.843c78",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 839.5,
        "y": 145,
        "wires": []
        "id": "6da9c580.db005c",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "x": 401.5,
        "y": 204,
        "wires": [
                "cbc9801c.5635e8"
        "id": "b69b8cef.4fec58",
        "type": "delay",
        "name": "",
        "timeout": "5",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "x": 389,
        "y": 443,
        "wires": [
                "a9865891.288bd"
        "id": "c7d3f01.b3cba1",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 355,
        "y": 337,
        "wires": []
        "id": "5fd52631.fe9be8",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 344.5,
        "y": 370,
        "wires": []
        "id": "f2afec2d.eb6ca",
        "type": "delay",
        "name": "",
        "timeout": "5",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "x": 832,
        "y": 217,
        "wires": [
                "f431570a.0bd32",
                "3d7e8aef.ff113e"
        "id": "efbc1126.53ca4",
        "type": "delay",
        "name": "",
        "timeout": "5",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "x": 802,
        "y": 449,
        "wires": [
                "f431570a.0bd32",
                "3d7e8aef.ff113e"
        "id": "f431570a.0bd32",
        "type": "and-gate",
        "name": "",
        "rules": [
                "t": "eq",
                "v": "OPEN",
                "vt": "str",
                "propertyType": "msg",
                "property": "payload",
                "topic": "door"
                "t": "eq",
                "v": "ON",
                "vt": "str",
                "topic": "mov"
        "outputTopic": "resultTopic",
        "gateType": "and",
        "emitOnlyIfTrue": true,
        "x": 1046.5,
        "y": 322,
        "wires": [
                "80597c64.31837",
                "be7ce667.592698"
        "id": "e36cea52.be3638",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 724,
        "y": 351,
        "wires": []
        "id": "f21e0fc0.db63e8",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 716.5,
        "y": 384,
        "wires": []
        "id": "80597c64.31837",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 1241,
        "y": 289,
        "wires": []
        "id": "be7ce667.592698",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 1231.5,
        "y": 321,
        "wires": []
        "id": "f1219097.361278",
        "type": "comment",
        "name": "Information!",
        "info": "This Flow aims to ask for 2 States of 2 Items and\ncheck for both results OPEN/ON to forward to the\nnext stepp.",
        "x": 656,
        "y": 547,
        "wires": []
        "id": "fc18ecd4.206ed",
        "type": "comment",
        "name": "inject topic door",
        "info": "",
        "x": 600.5,
        "y": 232,
        "wires": []
        "id": "127ea454.adb43c",
        "type": "comment",
        "name": "inject topic mov",
        "info": "",
        "x": 565,
        "y": 475,
        "wires": []
        "id": "3d7e8aef.ff113e",
        "type": "or-gate",
        "name": "",
        "rules": [
                "t": "eq",
                "v": "OPEN",
                "vt": "str",
                "topic": "door"
                "t": "eq",
                "v": "ON",
                "vt": "str",
                "topic": "mov"
        "outputTopic": "",
        "gateType": "or",
        "x": 1040.5,
        "y": 441,
        "wires": [
                "df869ae4.3bf64",
                "2ac08dd8.fb5fe2"
        "id": "c06f6f07.95d598",
        "type": "comment",
        "name": "INFO",
        "info": "This gate will only forward if the \"Door\" is OPEN\nand the Movement Detection is \"ON\"\n\n\"True Restriction\" meens only forward the payload\nif the gates is **green** TRUE",
        "x": 1037.5,
        "y": 290,
        "wires": []
        "id": "a0bf7769.6bf8c",
        "type": "comment",
        "name": "INFO",
        "info": "This gate will forward if the \"door\" is OPEN **OR**\nthe movment detection is ON\n\n\"True Restriction\" meens only forward the payload\nif the gates is **green** TRUE",
        "x": 1032,
        "y": 409,
        "wires": []
        "id": "df869ae4.3bf64",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 1218,
        "y": 421,
        "wires": []
        "id": "2ac08dd8.fb5fe2",
        "type": "debug",
        "name": "",
        "active": true,
        "console": "false",
        "x": 1207.5,
        "y": 454,
        "wires": []
Thank you so much i will give it try !
edit:now i got it :slight_smile:
and i think first exmaple has some issue, this is why i did not understand
the or gate was not working there i think…
I tested both gates, and both worked for me
Just thought this might be useful to someone… working with groups between Openhab and Node-red.
In this example we want to know the general state of the group, but also the member that caused it to turn to this state and use this information as a variable towards a Pushover notification. Let’s say a group containing door sensors (ON, OFF).
In my example i want to have a Pushover notification tell me which sensor caused the gDoorWindowSensorAllOO group to change to ON.
  • The group state is part of the msg.payload
  • The status of each individual members is provided as an array in msg.payload.members
  • gDoorWindowSensorAllOO is the Openhab group
  • Splitter is the node used to split every object in the array into separate messages
  • Switch is used to filter only the messages matching ON
  • The orange template node is used to format the Pushover message using a variable for the payload
  • the pushover Openhab is the actual pushover item that Openhab uses to send the pushover notification
Splitter (install the splitter node from the palette in Node-red)
Switch
Template Node
vPushover
[{"id":"c40cbb29.6ae5c8","type":"openhab2-get","z":"21a0918d.92d92e","name":"gDoorWindowSensorAllOO","controller":"be8b0821.df18b8","itemname":"gDoorWindowSensorAllOO","x":360,"y":300,"wires":[["c4e75089.d06b3"]]},{"id":"2b19c903.238346","type":"openhab2-out","z":"21a0918d.92d92e","name":"vPushover","controller":"be8b0821.df18b8","itemname":"vPushover","topic":"ItemUpdate","payload":"","x":1050,"y":300,"wires":[]},{"id":"2650a2cd.a46bbe","type":"template","z":"21a0918d.92d92e","name":"Send error info","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Door/Window open: {{payload.label}} !","output":"str","x":860,"y":300,"wires":[["2b19c903.238346"]]},{"id":"c4e75089.d06b3","type":"splitter","z":"21a0918d.92d92e","name":"","property":"payload.members","x":570,"y":300,"wires":[["49d325c0.7d5fdc"]]},{"id":"49d325c0.7d5fdc","type":"switch","z":"21a0918d.92d92e","name":"","property":"payload.state","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":300,"wires":[["2650a2cd.a46bbe"]]},{"id":"f3b75c98.93c21","type":"comment","z":"21a0918d.92d92e","name":"Split based on array","info":"Test","x":330,"y":260,"wires":[]},{"id":"be8b0821.df18b8","type":"openhab2-controller","z":"","name":"Openhab2 - Prod","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
Can you please confirm that the trailing ` is correct?
I am getting this error with it:
2018-11-20 11:46:31.786 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘vNotification.items’ has errors, therefore ignoring it: [2,43]: extraneous input ‘`’ expecting EOF
The trailing ’ is incorrect and should be removed. it will make your error/WARN go away
Everything works fine without it. Thanks.
I am very interesting in Node Red as alternative rule engine. And the most part from my old rules, I migrate to Node Red. On point is current still unclear for me. Maybe one of you have an idea.
In my old rules a use the astro events to make my garten light on or of. My rule is:
rule "Sonnenuntergang Event"
    Channel 'astro:sun:home:set#event' triggered START
    //Gartenbeleuchtung
    soS20_1.sendCommand(ON)
rule "Sonnenaufgang Event"
    Channel 'astro:sun:home:rise#event' triggered START
    //Gartenbeleuchtung
    soS20_1.sendCommand(OFF)
But with Node Red I tried sunevents and a lot of other nodes to use this logic in Node Red. I also tried the examples in this thread, but I did not get it working. Any idea to migrate my logic to Node Red?
BR
Rene
U can use the “bigtimer” node in node-red to accomplish this.
Thanks. I will try it.
New to red node, but have been trying to get alarm function flows up and running
I found a contrib node here: https://flows.nodered.org/node/node-red-contrib-alarm and installed it as it can be used with the homekit contrib node previously mentioned in this thread.
The node guide has this warning:
WARNING: There is NO infinite loop detection right now! So MAKE SURE if you create ANY path from a “StateChanged” to a “ChangeState” node, that you MUST ensure the loop is not permanent or you will burn up cpu! A good enhancement would be perhaps to build in a “keepalive” countdown for 2 iterations or something to auto-kill a message stuck in a loop if anyone wants to take that on.
How do I add such a function between the change status node and homekit item to stop infinite loops?
Thanks in advance. Apologies if I have missed any required details needed to answer the above
John
@john0wingnut - The RBE node is a good option for this. Only sends through a message if it’s payload is different from the previous message.
The other homekit node specific option will be seen in many of your other functions (since I know you’ve copied mine) the line you’re looking for is:
if (msg.hap.context !== undefined ) { }
Any script inside of the { } on that if statement will only happen if the message is from a homekit node. In other words, msg.hap.context is only defined if the message originated in a homekit node.
