Here my workaround for the broken Amazon Echo binding (Amazon dropped the API). It uses the Alexa-remote2-applestrudel nodes to connect to the Echos devices. It’s a local solution except the Amazon-registration of course.
edit: Updated to code to correctly detect the Echo Show
edit: Serial-IDs are now updated during each deploy. Ignore the warning.
edit: 11/17 Added aditional input devices (Sonos etc.)
edit: 11/18 removed "alexa " from lastVoiceCommand
edit 11/19 routines are now working too
edit 11/20 announce should work now
Remark: After adding routines or adding/changing echoes a new deploy is needed to read the IDs of echoes and routines.
ToDo:
- create .things file with your Echos, e.g. (you can create with UI too)
Bridge mqtt:broker:MosquittoMqttBroker {
Thing topic bad "Echo Bad" @ "Alexa" {
Channels:
Type string : speak "Sprechen" [ commandTopic="openhab/alexa/Bad/speak" ]
Type dimmer : volume "Lautstärke" [ commandTopic="openhab/alexa/Bad/volume" ]
Type dimmer : speakvolume "TTS Lautstärke" [ commandTopic="openhab/alexa/Bad/speakvolume" ]
Type string : routine "Routine starten" [ commandTopic="openhab/alexa/Bad/routine" ]
Type string : lastVoiceCommand "Letzter Sprachbefehl" [ stateTopic="openhab/alexa/Bad/state/lastVoiceCommand" ]
- connect your items to the channels (you can use the current ones from the binding)
- mqtt-server: install e.g. mosquitto with openhabian
- node-RED: you can install it with openhabian; open
http://<ip>:1880 - Install alexa-remote-applestrudel: manage palette - search applestrudel - install
- import the following flow
flow to import
"id": "tab_full_alexa",
"type": "tab",
"label": "Alexa MQTT Steuerung",
"disabled": false,
"info": "Alexa Steuerung über MQTT für openHAB"
"id": "mqtt_in_all",
"type": "mqtt in",
"z": "tab_full_alexa",
"name": "MQTT IN openhab/alexa/+/+",
"topic": "openhab/alexa/+/+",
"qos": "1",
"datatype": "auto-detect",
"broker": "mqttBrokerNode",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 157,
"y": 359.00000190734863,
"wires": [
"debug_pre",
"dynamic_router"
"id": "debug_pre",
"type": "debug",
"name": "Debug MQTT Raw",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 447,
"y": 459.00000190734863,
"wires": []
"id": "dynamic_router",
"type": "function",
"name": "Dynamic Router (global.echos)",
"func": "// Dynamic Router: benutzt global.echos (Name -> serial)\n// Topic: openhab/alexa/<DeviceName>/<action>\nconst parts = (msg.topic || \"\").split('/');\nconst deviceName = parts[2] || \"\";\nconst action = parts[3] || \"\";\nconst pl = msg.payload;\n\nlet deviceMap = global.get('echos') || {};\nif (!deviceMap || Object.keys(deviceMap).length === 0) {\n node.warn('global.echos leer — bitte Get Echo Devices ausführen');\n}\n\nconst serialNumber = deviceMap[deviceName];\nif (!serialNumber) {\n node.error(`Gerät '${deviceName}' nicht in global.echos gefunden!`);\n return null;\n}\n\nlet routineMap = global.get('routines') || {};\n\nmsg.device = deviceName;\nmsg.serialNumber = serialNumber;\n\nswitch(action) {\n case 'speak':\n // applestrudel erwartet msg.payload = { type:'speak', payload:{...} }\n msg.payload = {\n type: 'speak',\n payload: {\n type: 'regular',\n text: String(pl),\n devices: [serialNumber]\n }\n };\n return [msg, null, null, null, null];\n\n case 'volume':\n msg.payload = {\n type: 'volume',\n payload: {\n value: Number(pl),\n devices: [serialNumber]\n }\n };\n return [null, msg, null, null, null];\n\n case 'speakvolume':\n msg.payload = {\n type: 'volume',\n payload: {\n value: Number(pl),\n tts: true,\n devices: [serialNumber]\n }\n };\n return [null, null, msg, null, null];\n/*\n case 'announce':\n msg.payload = {\n type: 'speak',\n payload: {\n type: 'announce',\n text: String(pl),\n devices: [serialNumber]\n }\n };\n return [null, null, null, msg, null];\n*/\n case 'announce':\n msg.payload = {\n type: 'speak',\n payload: {\n type: 'announcement', // <-- genau SO\n text: String(pl),\n devices: [serialNumber]\n }\n };\n return [null, null, null, msg, null];\n \n case 'routine':\n // pl sollte der Name der Routine sein\n const routineName = String(pl);\n const routineId = routineMap[routineName];\n\n if (!routineId) {\n node.error(`Routine '${routineName}' nicht in global.routines gefunden!`);\n return null;\n }\n\n msg.device = serialNumber;\n\n msg.payload = {\n type: 'routine',\n payload: { \n routine: routineId,\n device: [serialNumber]\n }\n \n };\n return [null, null, null, null, msg];\n\n\n default:\n node.warn('Unknown action: ' + action);\n return null;\n}\n",
"outputs": 5,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 487,
"y": 379.00000190734863,
"wires": [
"alexa_speak"
"alexa_volume"
"alexa_speakvolume"
"alexa_announce"
"alexa_routine"
"id": "alexa_speak",
"type": "alexa-remote-routine",
"name": "Speak (TTS)",
"account": "alexaAccount",
"routineNode": {
"type": "msg",
"value": "payload"
"x": 800,
"y": 352.0000114440918,
"wires": [
"aeb6a85bf96f2203"
"id": "alexa_volume",
"name": "Set Volume",
"routineNode": {
"type": "msg",
"value": "payload"
"x": 800,
"y": 412.0000114440918,
"wires": [
"dd27d1421b70d630"
"id": "alexa_speakvolume",
"name": "Set Speak Volume",
"routineNode": {
"type": "msg",
"value": "payload"
"x": 820,
"y": 472.0000114440918,
"wires": [
"53f66119d2aa19cc"
"id": "alexa_announce",
"name": "Announcement",
"routineNode": {
"type": "msg",
"value": "payload"
"x": 810,
"y": 532.0000114440918,
"wires": [
"119a085384cd7368"
"id": "alexa_routine",
"name": "Run Routine",
"routineNode": {
"type": "msg",
"value": "payload"
"x": 800,
"y": 592.0000114440918,
"wires": [
"725e3e241d2ab282"
"id": "aeb6a85bf96f2203",
"type": "debug",
"name": "Debug speak",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1020,
"wires": []
"id": "dd27d1421b70d630",
"type": "debug",
"name": "Debug Volume",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1030,
"wires": []
"id": "53f66119d2aa19cc",
"type": "debug",
"name": "Debug Volume speak",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1050,
"wires": []
"id": "119a085384cd7368",
"type": "debug",
"name": "Debug Announcement",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1050,
"wires": []
"id": "725e3e241d2ab282",
"type": "debug",
"name": "Debug Routine",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1030,
"wires": []
"id": "e56772b842118878",
"type": "alexa-remote-event",
"name": "Event: ws-device-activity",
"event": "ws-device-activity",
"x": 143,
"y": 669.9999737739563,
"wires": [
"5aa56a1e63032694",
"b694145bf5b42a2a"
"id": "5aa56a1e63032694",
"type": "function",
"name": "get LastVoiceCommand",
"func": "// Alexa Voice History Parser → openHAB MQTT LastVoice\nlet data = msg.payload?.data;\nif (!data) { node.warn(\"No data found in payload\"); return null; }\nlet device = data.device?.deviceName || data.name || \"unknown\";\nlet command = data.description?.summary || data.voiceHistoryRecordItems?.[0]?.transcriptText || data.conversionDetails?.ASR_REPLACEMENT_TEXT?.[0]?.transcriptText || \"\";\nif (typeof command === \"string\") command = command.trim().replace(\"alexa \",\"\");\nif (!command) { return null; }\nmsg.topic = `openhab/alexa/${device}/state/lastvoice`;\nmsg.payload = command;\nreturn msg;",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 443,
"wires": [
"0a2ea769bbc9cc83",
"27fa01f87c858480"
"id": "0a2ea769bbc9cc83",
"type": "mqtt out",
"name": "MQTT OUT lastvoice",
"topic": "",
"qos": "1",
"retain": false,
"x": 713,
"wires": []
"id": "27fa01f87c858480",
"type": "debug",
"name": "Debug lastVoiceCommand",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 740,
"y": 740,
"wires": []
"id": "b694145bf5b42a2a",
"type": "debug",
"name": "Debug Alexa-Event",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 427,
"y": 721.9999775886536,
"wires": []
"id": "a051ec8e7b0e0ae1",
"type": "alexa-remote-echo",
"name": "Get Echo Devices",
"config": {
"option": "get",
"value": {
"what": "device",
"device": {
"type": "str",
"value": "ALEXA_ALL_DSN"
"x": 450,
"y": 160,
"wires": [
"filter_and_store_echos",
"09bd7f944bceb85a"
"id": "8d26706e30698739",
"type": "alexa-remote-init",
"name": "",
"option": "fresh",
"x": 720,
"y": 40,
"wires": [
"id": "77d971d3701e71c5",
"type": "inject",
"name": "Inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 490,
"y": 40,
"wires": [
"8d26706e30698739"
"id": "d92aeac196f76097",
"type": "debug",
"name": "Debug Echo Devices",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"x": 1040,
"y": 160,
"wires": []
"id": "filter_and_store_echos",
"type": "function",
"name": "Filter + Store Echo IDs",
"func": "// Kombinierter Filter + Store\nlet devices = msg.payload;\nif (!Array.isArray(devices)) { node.error(\"Payload ist kein Array!\", msg); return null; }\n\n// Filter: nur echte Echo-Geräte (deviceFamily ECHO oder ähnliche)\nlet out = devices\n .filter(d => d && d.deviceFamily && [\"ECHO\",\"KNIGHT\",\"ROOK\",\"SPEAKER\",\"WHA\"].includes (d.deviceFamily))\n .filter(d => d.accountName && d.serialNumber)\n .map(d => ({ name: d.accountName, serial: d.serialNumber }));\n\n// Map Name -> Serial\nlet map = {};\nout.forEach(d => { map[d.name] = d.serial; });\n\nglobal.set('echos', map);\nnode.warn('Saved echo map with ' + Object.keys(map).length + ' entries');\n\nmsg.payload = map;\nreturn msg;",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 742,
"y": 150.99999332427979,
"wires": [
"d92aeac196f76097"
"id": "startup_inject",
"type": "inject",
"name": "Startup Check (once)",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": "8",
"topic": "",
"payload": "",
"x": 162,
"wires": [
"a051ec8e7b0e0ae1",
"c52ce4618560cc94"
"id": "def522ed1b6c7a9d",
"type": "comment",
"name": "trigger in case you need a fresh authentication",
"info": "",
"x": 190,
"y": 40,
"wires": []
"id": "89a1d8e79f13e6b9",
"type": "comment",
"name": "auto-started ",
"info": "",
"x": 90,
"y": 100,
"wires": []
"id": "42b992407add7abe",
"type": "comment",
"name": "process commands from openHAB",
"info": "",
"x": 160,
"y": 300,
"wires": []
"id": "3b165086e9bc7115",
"type": "comment",
"name": "get lastVoiceCommand #1",
"info": "",
"x": 130,
"y": 620,
"wires": []
"id": "09bd7f944bceb85a",
"type": "debug",
"name": "Debug Echo Devices In",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 752,
"y": 110.99999332427979,
"wires": []
"id": "c52ce4618560cc94",
"type": "alexa-remote-other",
"name": "",
"config": {
"option": "get",
"value": {
"what": "automationRoutines"
"x": 470,
"y": 220,
"wires": [
"27f846f2267d9738",
"3d499beec2ed5034"
"id": "27f846f2267d9738",
"type": "function",
"name": "Filter + Store Routine IDs",
"func": "// Filter + Store Routine IDs\nlet routines = msg.payload;\nif (!Array.isArray(routines)) {\n node.error(\"Payload ist kein Array!\", msg);\n return null;\n}\n\nlet map = {};\nroutines.forEach(d => {\n if (d && d.name && d.automationId) {\n map[d.name] = d.automationId;\n }\n});\n\nglobal.set('routines', map);\nnode.warn('Saved routine map with ' + Object.keys(map).length + ' entries');\n\nmsg.payload = map;\nreturn msg;\n",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 750,
"y": 220,
"wires": [
"df7e7eb08ae91d0a"
"id": "df7e7eb08ae91d0a",
"type": "debug",
"name": "Debug Echo Routines",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1060,
"y": 220,
"wires": []
"id": "3d499beec2ed5034",
"type": "debug",
"name": "Debug Echo Routines In",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 750,
"y": 280,
"wires": []
"id": "mqttBrokerNode",
"type": "mqtt-broker",
"name": "MQTT 192.168.1.11",
"broker": "192.168.1.11",
"port": "1883",
"clientid": "nodered-alexa",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
"id": "alexaAccount",
"type": "alexa-remote-account",
"name": "Amazon DE Account",
"authMethod": "proxy",
"proxyOwnIp": "192.168.1.11",
"proxyPort": "5678",
"cookieFile": "/home/openhabian/.node-red/alexa.cookie",
"refreshInterval": "",
"alexaServiceHost": "layla.amazon.de",
"pushDispatchHost": "",
"amazonPage": "amazon.de",
"acceptLanguage": "de-DE",
"onKeywordInLanguage": "",
"userAgent": "",
"usePushConnection": "on",
"autoInit": "on",
"autoQueryActivityOnTrigger": "on"
"id": "d3f2427250f823f9",
"type": "global-config",
"env": [],
"modules": {
"node-red-contrib-alexa-remote2-applestrudel": "5.0.55"
- add your accounts for mqtt-user and amazon-account in both nodes
- deploy
- follow the message to register your amazon account
- enjoy
Please test and report if something is wrong or too unprecise.
TTS works well, lastVoiceCommand is currently not reliable. Maybe I still got a bug somewhere or the event is not always triggered by Amazon.
It’s my very first try with node-RED so hints how to improve are really welcome.
