I’m having a test with a cable cat 5 L= 10mt. and a power adaptor 5V 2.1A.
Is working but, the temperature is about 0,5°-1°C higher than the sensors with a short cable.
The humidity is more or less the same than other sensors.
For Google App, there is no way than configure the items as thermostat, but is possible to create a rules only for google?
TnX all for the help.
Jad
P.S. after 30 min the temperature is quite the same then the other sensors.
in this case I make an adjustment of “- .5” for the temperature.
The slash “/” is more or less philosophical. I think it depends on how your Controller-Subscribe is declared. If you use it this way /%sysname%/# you will need the slash, if using in that way %sysname%/# no slash is needed. Also other possibilities are usable, i.e. %sysname%_%unit%/# means “Unit-Name”, “_” the underscore-sign as a seperator and %unit% which is the unit number
