- Platform information:
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
openHAB 2.2.0-1 (Release Build)
I’m a beginner but already running some fibaro roller shutters…
I run into some issues trying to add ZRC90-EU Scene Master (still doesn’t work but I’ll open a new thread for this once that issue will be solved)
Steps I did:
–>tried to add the ZRC90-EU Scene Master to existing Z Wave network by pressing the L button on it
1st attempt: got an undefined device (as node 6) so deleted it from controller using PAPER UI
2nd attempt: the ZRC90-EU Scene Master was recognized but I never got the Scene_Number get work (never seen any entry in the event log) so deleted it from controller using PAPER UI
3rd attempt:same as in attempt 1
At least tried dome more things and end with 4 devices being discovered by Paper UI inbox…
Before I’l start the inclusion of the ZRC90-EU Scene Master once again (with help of the forum :-)) I would like to delete the devices from the PaperUI inbox…
So tried to follow steps I found in the forum:
–>add the device
–>mark it as failed device
–>remove it from the controller
But as soon the step “mark as failed device” will be executed an error will be shown: “error while executing the command”. I tried it using PaperUi and Habmin GUI
Found following in the openhub.log:
2018-09-14 13:25:42.746 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zwave:device:f1caec1a:node9/config’
at org.eclipse.smarthome.config.xml.AbstractXmlBasedProvider.get(AbstractXmlBasedProvider.java:151) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.AbstractXmlConfigDescriptionProvider.getConfigDescription(AbstractXmlConfigDescriptionProvider.java:50) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:152) [103:org.eclipse.smarthome.config.core:0.10.0.b1]
at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:188) [103:org.eclipse.smarthome.config.core:0.10.0.b1]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.normalizeConfiguration(ThingResource.java:735) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:415) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor59.invoke(Unknown Source) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Could someone help me in this matter?
