I have Spent one day trying to expose one item to MYOpenHab.com but it didn’t work for me
I am getting this error messages in the LOG I think it is related to the issue I face :
2019-08-08 09:32:00.179 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2019-08-08 09:32:00.193 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 3270d73e-f145-4e11-a302-160038d907c7, base URL = http://localhost:8080)
2019-08-08 09:32:00.404 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 3270d73e-f145-4e11-a302-160038d907c7, base URL = http://localhost:8080)
2019-08-08 09:32:27.144 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
io.socket.engineio.client.EngineIOException: xhr post error
at io.socket.engineio.client.Transport.onError(Transport.java:71) [237:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.PollingXHR.access$000(PollingXHR.java:19) [237:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.PollingXHR$4$1.run(PollingXHR.java:88) [237:org.openhab.io.openhabcloud:2.4.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [237:org.openhab.io.openhabcloud:2.4.0]
Caused by: java.io.IOException: 400
at io.socket.engineio.client.transports.PollingXHR$Request$1.run(PollingXHR.java:218) ~[?:?]
... 1 more
2019-08-08 09:32:27.195 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 3270d73e-f145-4e11-a302-160038d907c7, base URL = http://localhost:8080)
2019-08-08 09:32:28.573 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 3270d73e-f145-4e11-a302-160038d907c7, base URL = http://localhost:8080)
2019-08-08 09:37:00.339 [WARN ] [okhttp3.OkHttpClient ] - A connection to https://myopenhab.org/ was leaked. Did you forget to close a response body?
and here is my configuration file for the cloud service
############################## openHAB Cloud Connector #############################
# The URL of the openHAB Cloud service to connect to.
# Optional, default is set to the service offered by the openHAB Foundation
# (https://myopenhab.org/)
baseURL=https://myopenhab.org/
# Defines the mode in which you want to operate the connector.
# Possible values are:
# - notification: Only push notifications are enabled, no remote access is allowed.
# - remote: Push notifications and remote access are enabled.
# Optional, default is 'remote'.
mode=remote
# A comma-separated list of items to be exposed to external services like IFTTT.
# Events of those items are pushed to the openHAB Cloud and commands received for
# these items from the openHAB Cloud service are accepted and sent to the local bus.
# Optional, default is an empty list.
expose=Oo_06_05
and I have updated the item State many times and rebooted the whole system but still not exposing that item !
Any Clue ?
