I am running Debian 7 I have tried to login remotely from my windows laptop. I am using user openhab/habopen on OH2 I get the login screen but I do not know the user or passwords
Did u installed the openHABian destri ? if yes its openhabian as user and pw
Not an OpenHabian install but I tried anyway and it did not work. I just installed OH2 from the stable repository. Any idea what the ssh login is?
I got in on port 22 and using the login for my cubie board root/cubieboard
Yes I can log in now Thanks
The web server is not running and I get this when I check status
root@cubieboard2:~# sudo /etc/init.d/openhab2 status
status: Ignoring predefined value for KARAF_HOME
/usr/share/openhab2/runtime/bin/karaf: line 355: [: : integer expression expected
Exception in thread “main” java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Integer.java:542)
at java.lang.Integer.parseInt(Integer.java:615)
at org.apache.karaf.main.Status.getPortFromShutdownPortFile(Status.java:79)
at org.apache.karaf.main.Status.main(Status.java:41)
root@cubieboard2:~# login as: root
Bob Moors
5725 Beach Dr
Panama City Beach, Fl 32408
817 564 6304
You’ll need to provide a little more backstory if you are looking for help. Also be sure to follow the instructions given on docs.openhab.org.
