Platform information:
- Hardware: Raspi /1GB RAM/30 GB
- OS: openhabian
- Java Runtime Environment: which java platform is used and what version
- openHAB version: OH3
Issue of the topic: please be detailed explaining your issue
Not able to update the location in Sitemap -
Please post configurations (if applicable):
items/lpg.items
Contact Kitchen_Light “Warning”
Number Kitchen_Humidity “LPG Level”
Location Kitchen_Location " Location"
String llpgLocPos {channel=“mqtt:broker:mosquitto:lpgTopic :llpgLoc”}
things/lpg.things
Bridge mqtt:broker:mosquitto [ host=“localhost”, secure=false ]
Thing topic lpgTopic {
Channels:
Type string: llpgLoc “LPG Location” [stateTopic="/traccar/lpg1/status"]
mosquitto_sub
$ mosquitto_sub -t /traccar/lpg1/status
{“latitude”:18.9711486,“longitude”:72.8374287}
sitemaps/lpg.sitemap
sitemap lpg label=“Track-N-Trace” {
Group item=Kitchen_Light
Group item=Kitchen_Humidity
Frame {
Group item=Kitchen_Location
rules/lpg.rules
rule “Location MQTT”
Item llpgLocPos changed
logInfo(“LPGTracks”,“MQTT update”)
val String json = llpgLocPos.state
logInfo("LPGTracks MQTT","Inside point")
val String lat = transform("JSONPATH", "$.lat", json)
val String lon = transform("JSONPATH", "$.lon", json)
Kitchen_Location.postUpdate(new PointType(lat + "," + lon))
sitemap lpg label=“LPG Track-N-Trace”
Frame {
Frame {
Group item=Settings
- If logs where generated please post these here using code fences:
2022-03-05 08:14:08.075 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘lpg.rules’
2022-03-05 08:14:51.087 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Humidity’ is not a group.
2022-03-05 08:14:51.092 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Light’ is not a group.
2022-03-05 08:14:51.095 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Location’ is not a group.
2022-03-05 08:14:51.101 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Humidity’ is not a group.
2022-03-05 08:14:51.107 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Light’ is not a group.
2022-03-05 08:14:51.117 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item ‘Kitchen_Location’ is not a group.
