I am able to pair my node successfully, and able to control my node from openhab UI. But I am not able to update data on openhab when sending from node. As I am using, silicon lab’s MGM13p Zigbee module as node and raspberry pi3 installing openhab server. I am trying to update temperature on openhab paper UI.
Hi, which version of openHAB
Which binding
What’s your things and items configure?
Hi vzorglub,
I am using v2.4 of openhab, with zigbee binding. I am using custom hardware with MGM13p silicon lab’s zigbee soc. I am trying to implement temperature sensor node.
What’s your things and items configurations?
Hi vzorglub,
My thing is Ember EM35x coordinater, and I have created two items for Temperature and Switch.
Can you post the configuration for the thing and items, please?
Sorry,
Configuration for things, where can I get. Is this what I have to send
Paper UI_thing.pdf (80.0 KB)
Paper UI_temp.pdf (68.7 KB)
What sensor are you using?
Did you create the sensor thing?
Then you’ll have to link the items to the sensor thing channels
What I am trying to do is, I am trying to send Custom temperature data which I am getting from HDC1080 sensor. My node is transmitting data successfully to the server but I am getting message “Incoming message did not translate to command.” in debug log
2019-01-30 12:52:19.147 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=260, clusterId=1026, sourceEndpoint=4, destinationEndpoint=4, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=104], lastHopLqi=128, lastHopRssi=-68, sender=9963, bindingIndex=255, addressIndex=255, messageContents=09 0C 00 FA FF FF FF FE FF]
2019-01-30 12:52:19.151 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=9963/4, destinationAddress=0/4, profile=0104, cluster=1026, addressMode=null, radius=0, apsSecurity=false, apsCounter=104, payload=09 0C 00 FA FF FF FF FE FF]
2019-01-30 12:52:19.153 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=12, commandId=0]
2019-01-30 12:52:19.167 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - No command type found for CLUSTER_SPECIFIC_COMMAND, cluster=1026, command=0, direction=SERVER_TO_CLIENT
2019-01-30 12:52:19.168 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Incoming message did not translate to command.
2019-01-30 12:52:19.178 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=9963, apsFrame=EmberApsFrame [profileId=260, clusterId=1026, sourceEndpoint=1, destinationEndpoint=4, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY], groupId=0, sequence=48], messageTag=26, status=EMBER_SUCCESS, messageContents=]
2019-01-30 12:52:19.181 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=9963, apsFrame=EmberApsFrame [profileId=260, clusterId=1026, sourceEndpoint=1, destinationEndpoint=4, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY], groupId=0, sequence=48], messageTag=26, status=EMBER_SUCCESS, messageContents=]
