mredant
(M Redant)
#1
only one item (presence) is shown on my.openhab
and in IFTTT there are none?
DO I need to change (in openhab.cfg) (and reboot?)
persistence:default=rrd4j
to
persistence:default=myopenhab.persist
this is my items-file:
Group gMobiles
Switch Presence “X or Y [MAP(presence.map):%s]” { someBinding:somevalue }
Switch phone1 “Y home” (gMobiles) {nh=“192.168.0.***”}
Switch phone2 “X home” (gMobiles) {nh=“192.168.0.***”}
Switch sunset "Donker"
Switch schak8 “GPIO8” {gpio=“pin:8”}
Switch schak9 “GPIO9” {gpio=“pin:9”}
sihui
(SiHui)
#2
No, you don’t have to.
Create a file named myopenhab.persist and put it in your persistence folder:
Strategies {
default = everyChange
Items {
* : strategy = everyChange
This will persist everything.
Edit: and for IFTTT you need to activate the openhab channel:
https://my.openhab.org/docs/ifttt
mredant
(M Redant)
#3
hm, everything is already set like you say
sihui
(SiHui)
#4
Hmm, then double check if you have any typos (maybe use the automatic checking of OH Designer), if you have the correct file name syntax …
