Hey Rich,
do you know if this answer you provided is is still true?
I tried this one
Member of gAlarms changed to !NULL
but does not work. Just wanted to double check.
Hey Rich,
I tried this one
No, you cannot do any sort of comparisons, boolean operations, or mathematical operations in a rule’s trigger.
To do a test like that you’d use a rule condition in the UI or an if statement in the body of your rule in a text file.
