Not work! Failed to initialize Atmosphere Framework
OpenHab 1.8.2 restart, and this ERROR. Raspberry Pi, Debian, Jessie.
Please help!
20:50:43.930 [ERROR] [sphere.cpr.AtmosphereFramework:906 ] - Failed to initialize Atmosphere Framework
java.lang.InternalError: java.util.zip.ZipException: invalid CEN header (bad compression method)
at sun.misc.URLClassPath$JarLoader.getResource(URLClassPath.java:1003) ~[na:1.8.0_73]
at sun.misc.URLClassPath.getResource(URLClassPath.java:212) ~[na:1.8.0_73]
at sun.misc.URLClassPath.getResource(URLClassPath.java:265) ~[na:1.8.0_73]
at java.lang.ClassLoader.getBootstrapResource(ClassLoader.java:1261) ~[na:1.8.0_73]
at java.lang.ClassLoader.getResource(ClassLoader.java:1090) ~[na:1.8.0_73]
at java.lang.ClassLoader.getResource(ClassLoader.java:1088) ~[na:1.8.0_73]
at java.lang.ClassLoader.getSystemResource(ClassLoader.java:1223) ~[na:1.8.0_73]
at java.lang.ClassLoader.getSystemResourceAsStream(ClassLoader.java:1326) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.reflect.opt.AccessorInjector.tailor(AccessorInjector.java:103) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.reflect.opt.AccessorInjector.prepare(AccessorInjector.java:68) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.reflect.opt.OptimizedAccessorFactory.get(OptimizedAccessorFactory.java:164) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.reflect.Accessor$FieldReflection.optimize(Accessor.java:271) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.property.ArrayProperty.(ArrayProperty.java:53) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.property.ArrayERProperty.(ArrayERProperty.java:73) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.property.ArrayElementProperty.(ArrayElementProperty.java:85) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.property.ArrayElementNodeProperty.(ArrayElementNodeProperty.java:47) ~[na:1.8.0_73]
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[na:1.8.0_73]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[na:1.8.0_73]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[na:1.8.0_73]
at java.lang.reflect.Constructor.newInstance(Constructor.java:422) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.property.PropertyFactory.create(PropertyFactory.java:113) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.ClassBeanInfoImpl.(ClassBeanInfoImpl.java:166) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.getOrCreate(JAXBContextImpl.java:488) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.(JAXBContextImpl.java:305) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.(JAXBContextImpl.java:124) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1123) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.ContextFactory.createContext(ContextFactory.java:147) ~[na:1.8.0_73]
at com.sun.xml.internal.bind.v2.ContextFactory.createContext(ContextFactory.java:271) ~[na:1.8.0_73]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_73]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_73]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_73]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_73]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:171) ~[na:1.8.0_73]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:131) ~[na:1.8.0_73]
at javax.xml.bind.ContextFinder.find(ContextFinder.java:356) ~[na:1.8.0_73]
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:431) ~[na:1.8.0_73]
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:394) ~[na:1.8.0_73]
at com.sun.jersey.server.impl.wadl.WadlApplicationContextImpl.(WadlApplicationContextImpl.java:103) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.wadl.WadlFactory.init(WadlFactory.java:100) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.RootResourceUriRules.initWadl(RootResourceUriRules.java:169) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.RootResourceUriRules.(RootResourceUriRules.java:106) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._initiate(WebApplicationImpl.java:1359) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.access$700(WebApplicationImpl.java:180) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl$13.f(WebApplicationImpl.java:799) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl$13.f(WebApplicationImpl.java:795) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.inject.Errors.processWithErrors(Errors.java:193) ~[jersey-core-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.initiate(WebApplicationImpl.java:795) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.initiate(WebApplicationImpl.java:790) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.initiate(ServletContainer.java:491) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer$InternalWebComponent.initiate(ServletContainer.java:321) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.load(WebComponent.java:605) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.init(WebComponent.java:207) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.init(ServletContainer.java:376) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.init(ServletContainer.java:559) ~[jersey-servlet-1.18.1.jar:1.18.1]
at javax.servlet.GenericServlet.init(GenericServlet.java:244) ~[javax.servlet_3.0.0.v201112011016.jar:na]
at org.atmosphere.util.AtmosphereFilterChain.init(AtmosphereFilterChain.java:89) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.init(ReflectorServletProcessor.java:297) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor.init(ReflectorServletProcessor.java:176) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.initAtmosphereHandler(AtmosphereFramework.java:1573) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.init(AtmosphereFramework.java:891) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.init(AtmosphereFramework.java:780) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.configureFramework(AtmosphereServlet.java:101) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.init(AtmosphereServlet.java:80) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.init(ServletRegistration.java:49) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.registerServlet(ProxyServlet.java:179) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.registerServlet(HttpServiceImpl.java:66) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.openhab.io.rest.RESTApplication.activate(RESTApplication.java:141) [org.openhab.io.rest_1.8.2.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:343) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
Caused by: java.util.zip.ZipException: invalid CEN header (bad compression method)
at java.util.zip.ZipFile.open(Native Method) ~[na:1.8.0_73]
at java.util.zip.ZipFile.(ZipFile.java:219) ~[na:1.8.0_73]
at java.util.zip.ZipFile.(ZipFile.java:149) ~[na:1.8.0_73]
at java.util.jar.JarFile.(JarFile.java:166) ~[na:1.8.0_73]
at java.util.jar.JarFile.(JarFile.java:103) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader.getJarFile(URLClassPath.java:893) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader.access$700(URLClassPath.java:756) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader$1.run(URLClassPath.java:838) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader$1.run(URLClassPath.java:831) ~[na:1.8.0_73]
at java.security.AccessController.doPrivileged(Native Method) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader.ensureOpen(URLClassPath.java:830) ~[na:1.8.0_73]
at sun.misc.URLClassPath$JarLoader.getResource(URLClassPath.java:1001) ~[na:1.8.0_73]
… 94 common frames omitted
New firmware fix this problem:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
sudo reboot now
