Hi!
I’m facing an issue with MQTT binding. When I start OpenHAB 3.3.0 via ssh on my raspberry, everything works fine, but I need to have the ssh session running all the time and cannot disconnect my laptop from the network, otherwise OpenHAB gets killed.
So I created an init script using start-stop-daemon, which is basically just running the start.sh the same way as I run it and also using the same user. But when started like that, it crashes during the startup and it is 100% reproducible. I can see following exceptions in openhab.log:
2022-08-25 22:16:57.339 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler@1b13535': null
at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.initialize(GenericMQTTThingHandler.java:154) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2022-08-25 22:16:57.438 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'mqtt:topic:victronMqttBroker:EssBattery': null
Any idea why this happens only when not started via ssh and how to fix it?
