REST API throws NPE when called with things?summary=true. This results in empty Things page on MainUI. Full response body: "{\"error\":{\"http-code\":500,\"exception\":{\"class\":\"java.lang.NullPointerException\"}}}"
It can be reproduced with API Explorer by MainUI. There is nothing in the log, even though I already increased some log levels. Calling without ?summary=true works fine.
Not sure how to get the stacktrace. But if you run this in eclipse you can set a breakpoint on when a NullPointerException is thrown. This will stop the code at the point this exception is thrown. This might help finding the issue.
Okay, that would mean I have to run openHAB in debug mode all the time, because this issue is solved by restarting openHAB and sometimes occurs again after some time. I’ll try that.
