NPE when changing name of a specific z-wave thing
Hey,
whenever I change the name of a specific z-wave device thing, a Fibaro FGD212 Dimmer 2, i get a Java NullPointerException. The name will be updated successfully, so its basically no problem, but that error does not seem right to me. It only happens to that one z-wave device.
I sometimes also get other errors for that node, so something might not be right at all with this node.
This is the log for the NPE:
23:14:30.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Handler disposed. Unregistering listener.
23:14:30.058 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 8: Serialise aborted as static stages not complete
23:14:30.059 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
23:14:30.065 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Controller status changed to ONLINE.
23:14:30.065 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Controller is ONLINE. Starting device initialisation.
23:14:30.067 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Updating node properties.
23:14:30.068 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:9502f23c:node8' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
23:14:30.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Updating node properties. MAN=271
23:14:30.069 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Updating node properties. MAN=271. SET. Was 271
23:14:30.072 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:9502f23c:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
23:14:30.071 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while calling thing updated at ThingHandler 'org.openhab.binding.zwave.handler.ZWaveThingHandler@b2d85b': java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_111]
	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_111]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)
	at org.eclipse.smarthome.core.thing.internal.ThingManager.thingUpdated(ThingManager.java:518)
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:227)
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:150)
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1)
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:167)
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:57)
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:82)
	at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.update(AbstractManagedProvider.java:134)
	at org.eclipse.smarthome.io.rest.core.thing.ThingResource.update(ThingResource.java:415)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
	at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[10:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[77:org.eclipse.jetty.security:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.Server.handle(Server.java:499)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[70:org.eclipse.jetty.io:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[81:org.eclipse.jetty.util:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[81:org.eclipse.jetty.util:9.2.19.v20160908]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Caused by: java.lang.NullPointerException
	at org.openhab.binding.zwave.handler.ZWaveThingHandler.updateNodeProperties(ZWaveThingHandler.java:1393)[194:org.openhab.binding.zwave:2.0.0.201701032212]
	at org.openhab.binding.zwave.handler.ZWaveThingHandler.bridgeStatusChanged(ZWaveThingHandler.java:454)[194:org.openhab.binding.zwave:2.0.0.201701032212]
	at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialize(ZWaveThingHandler.java:147)[194:org.openhab.binding.zwave:2.0.0.201701032212]
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:192)[103:org.eclipse.smarthome.core.thing:0.9.0.201612221226]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$7.call(ThingManager.java:522)[103:org.eclipse.smarthome.core.thing:0.9.0.201612221226]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$7.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201612221226]
	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[96:org.eclipse.smarthome.core:0.9.0.201612221226]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_111]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_111]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_111]
	... 1 more
23:14:30.135 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'zwave:device:9502f23c:node8' has been updated.
Updated the binding two days ago, so its almost up to date.
One of the other errors I mentioned before (not sure if related):
23:19:45.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Configuration update received
23:19:45.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Configuration update config_1_1 to 1
23:19:45.500 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Error getting configurationCommandClass
And another one…
18:56:42.897 [ERROR] [col.security.ZWaveSecureNonceTracker] - NODE 8: SECURITY_ERROR Device message contained nonce that is unknown to us, id=-101.
18:56:43.019 [ERROR] [mmandclass.ZWaveSecurityCommandClass] - NODE 8: SECURITY_ERROR MAC Authentication of packet failed. Dropping.
18:56:43.022 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 8: Failed to decrypt message out of Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 08 1E 98 81 AE DB 67 15 52 F6 2E E2 91 15 37 6F BB B6 8A 6F 46 F8 72 9B 69 4B BA 08 C8 D2 3C B1  .
19:03:34.549 [ERROR] [curityCommandClassWithInitialization] - NODE 8: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
19:03:34.578 [ERROR] [curityCommandClassWithInitialization] - NODE 8: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
19:03:34.608 [ERROR] [curityCommandClassWithInitialization] - NODE 8: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
19:03:34.638 [ERROR] [curityCommandClassWithInitialization] - NODE 8: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
19:03:34.667 [ERROR] [curityCommandClassWithInitialization] - NODE 8: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
19:03:34.697 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 8: Node advancer: Retries exceeded at STATIC_VALUES
Regards, Tobi
