Hello everybody,
am new here in this community and I am a newbie working with this system.
My Problem is, that my installation of frontail aborts with following Errors:
Open a Github issue and provide the log mentioned in the last line, please.
Also explain the steps you took to install openHABian. Normally, that part of the code is executed on initial unattended installation run but I suspect you didn’t follow the install instructions.
Ive followed all the instructions they where available in the www. Ive download the image : openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img.xz
than mounted with Etcher to a 32GB card
put it into my Raspberry an powered on.
After installing, I´ve connected with putty to Openhabianpi an started with the config the systemupdates. Installing the Log Viewer stopped
Did you use wlan when installing at the first time? It’s a known bug that wlan availability is not certain at first boot.
Please always start with lan for setup, then (after the system is completely up and running) change to wlan (if needed).
Hello Udo, I use only Lan for the connection to the raspberry at time.
At time I have no Idea how to solve this problem.
Thanks for all answers and instructions to help me with this problem.
CLI = Command Line Interface. You used that to run openhabian-config.
So try sudo apt-get upgrade --yes --force-yes.
If I correctly understood you then the initial install finished ?
Then you started openhabian-config and selected menu option 02?
If so you can simply proceed although you should still try to fix that as I wrote.
You must be precise in describing what you did else we can’t help and cannot know if this might also affect other users.
The logviewer should already have been installed during unattented install phase but eventually something went wrong there. Either way step 9 is not needed.
Did the install finish before you logged in ? Can you provide /boot/first-boot.log ?
And please in a Github issue, not here.
You may continue with your OH setup. Logviewer may work or not but the rest should be fine.
I repeated the steps and get the same error. However, like @mstormi says the log viewer is already installed and is still working (even after this error). The error also says that it is ‘refusing to remove it’.
For peace of mind, you could flash your sdcard again now that you know that the log viewer is already installed by default.
