# NTP Binding PaperUI vs. Sitemap
**URL:** <https://community.openhab.org/t/ntp-binding-paperui-vs-sitemap/24610>\
**Category:** Bindings\
**Created:** [March 7, 2017, 4:47pm UTC](https://community.openhab.org/t/ntp-binding-paperui-vs-sitemap/24610 "2017-03-07T16:47:02Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Talcom](https://community.openhab.org/user_avatar/community.openhab.org/talcom/32/5433_2.png) [@Talcom](https://community.openhab.org/u/Talcom)\
**Post date:** [March 7, 2017, 4:47pm UTC](https://community.openhab.org/t/ntp-binding-paperui-vs-sitemap/24610/1 "2017-03-07T16:47:02Z")
</div>
Hello Community,
when I take a look at an NTP item in the “Control” View in Openhab2 it shows the corrcet time.
When I look at the same item used in my own sitemap there is one hour difference between them.
In my sitemap I want to see the current local time. So I use the following code
```auto
Text item=NTPTime
The configuration of the item is:
```auto
DateTime NTPTime "NTP Time [%1$td.%1$tm.%1$tY %1$tT]" <clock> {channel="ntp:ntp:local:dateTime"}
The configuration of the thing is:
```auto
ntp:ntp:local [hostname="0.pool.ntp.org", refreshInterval=60, refreshNtp=30, locale="", timeZone="Europe/Berlin"]
Has anybody a hint for my problem?
**Author:** ![hakan](https://community.openhab.org/user_avatar/community.openhab.org/hakan/32/70815_2.png) [@hakan](https://community.openhab.org/u/hakan)\
**Post date:** [March 7, 2017, 5:22pm UTC](https://community.openhab.org/t/ntp-binding-paperui-vs-sitemap/24610/2 "2017-03-07T17:22:38Z")
</div>
> [@Talcom](#):
What is your timezone setting? In the operating system and in your openHAB installation?
See also the answers in the following thread:
> [@\[SOLVED\] Timezone: "now" always refers to UTC?](https://community.openhab.org/t/solved-timezone-now-always-refers-to-utc/3721):
> Hey there! I mentioned if I use “now” inside my rules it seems to be UTC always, not considering my timezone or daylight saving time. Same thing if I use charts the time is also UTC. My workaround currently is to hard-code time difference and use a switch to set or unset daylight saving time. This is a bit awkward. Does openHAB offer anything to consider timezone and daylight saving time automatically? Currently I am using openHAB version 1.6.2. As I am new to openHAB I think this is a begi…
