Hi all,
testing a new zigbee two channel relay, I noticed a null pointer exception (see log file attached) which appears every time after I switched the device. This is not a real problem for me as the relay works. However, I guess this should be fixed somewhere?
Device: Xiaomi two way relays LLKZMK11LM
Openhab: 2.5.0 M1
Annotations:
- The linked items are configured as autoupdate = false and I manually send a refresh command. Maybe this is relevant when reading the log file.
- I also use some other switches, they do not show this problem.
2019-06-15 16:14:11.441 [ERROR] [tworkManager$AFMessageListenerFilter] - Error AF message listener notify.
at com.zsmartsystems.zigbee.serialization.DefaultDeserializer.readZigBeeType(DefaultDeserializer.java:72) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.zcl.field.AttributeReport.deserialize(AttributeReport.java:100) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.zcl.ZclFieldDeserializer.deserialize(ZclFieldDeserializer.java:73) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.zcl.clusters.general.ReportAttributesCommand.deserialize(ReportAttributesCommand.java:88) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.receiveZclCommand(ZigBeeNetworkManager.java:808) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.receiveCommand(ZigBeeNetworkManager.java:731) ~[201:com.zsmartsystems.zigbee:1.1.6]
at com.zsmartsystems.zigbee.dongle.cc2531.ZigBeeDongleTiCc2531.notify(ZigBeeDongleTiCc2531.java:316) ~[202:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
at com.zsmartsystems.zigbee.dongle.cc2531.network.ZigBeeNetworkManager$AFMessageListenerFilter.receivedAsynchronousCommand(ZigBeeNetworkManager.java:1288) [202:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
at com.zsmartsystems.zigbee.dongle.cc2531.network.impl.CommandInterfaceImpl.notifyAsynchronousCommand(CommandInterfaceImpl.java:382) [202:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
at com.zsmartsystems.zigbee.dongle.cc2531.network.impl.CommandInterfaceImpl.handlePacket(CommandInterfaceImpl.java:160) [202:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketParser.run(ZToolPacketParser.java:116) [202:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
Here is the complete log file including one null pointer exception after switching ON and one null pointer exception after switching OFF: zigbee_log.txt (99.2 KB)
Kind regards!
