OK, this is driving me crazy. I have a Number Item that is used to set the temperature of multiple thermostats in a room. I put it in a sitemap using a SetPoint Item and when I change the number, the SetPoint value is not update, but the temperature is set. If I put the same item in another part of the same sitemap everything works fine.
This all works well both in Classic UI and on the Android App.
Here is my sitemap:
// Works as expected
Group item=Test {
Setpoint label="Wohnzimmer [%.1f °C]" item=WZAllTempSet minValue=4.5 maxValue=30 step=0.5
// Does not update displayed value, but related rules execute
Frame label="Wohnung"{
Group item=Wohnzimmer {
