I’m trying to modify a numeric value received e.g. by the darksky binding by a simple multiplication.
My assumption was that this should be easy by using a profile using the JavaScript transform as shown below.
My item definition is:
Number:Speed localDailyForecastTodayRainIntensity "Rain intensity for today [%.2f mm/h]" <rain> { channel="darksky:weather-and-forecast:api:local:forecastToday#rain" [profile="transform:JS", function="multiply24.js"]}
The JavaScript Transformation is installed and active.
The “multiply24.js” (Don’t be confused by the name, I’ve stripped the script down during debugging…)
(function(i) {
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("multiply24.js");
logger.warn(typeof i);
logger.warn(i);
/* return i * 24; */
return "0.7";
})(input)
The relevant log output is:
2020-06-06 19:13:04.580 [WARN ] [multiply24.js ] - string
2020-06-06 19:13:04.582 [WARN ] [multiply24.js ] - 0.2864 µ(km/h)
so it looks like the transform is called and running.
Anyhow I did not find a solution in returning the correct format.
Neither string (return “0.7”) nor a numeric value (return 0.7) is accepted. In either case the item is not updated.
When changing the item type from “Number:Speed” to “String” everything is working as expected - but I need a numeric item…
Does anyone have a clue on how to achieve this?
Regards
Dirk
