import java.net.URLEncoder
var ZonedDateTime LIVACCOM_EtaStart = null
rule "Detect LIV AC Compressor on"
Item velbusGU44RYLDACAddress04_LIVACCOMP changed from OFF to ON
logInfo("AC","LIVING ROOM COMPRESSOR ON")
// this is to calculate the minutes per day for the AC compressor to be on
LIVACCOM_EtaStart = now
rule "Detect LIV AC Compressor OFF"
Item velbusGU44RYLDACAddress04_LIVACCOMP changed from ON to OFF
var LIVACCOM_EtaDelta = Duration.between(LIVACCOM_EtaStart, now)
var Number LIVACCOM_EtaRunTime = LIVACCOM_EtaDelta.toSeconds
logInfo("AC","Running for - " + LIVACCOM_EtaRunTime)
var Number LIVoldValueRunTime = (LIVACCOM_SecondsPerDay.state as Number)
logInfo("AC","old value - " + LIVoldValueRunTime)
if (LIVoldValueRunTime == NULL) {
logInfo("AC","old value was NULL - " + LIVoldValueRunTime)
LIVoldValueRunTime = 0
var LIVACCOM_TotalRunTime = (LIVoldValueRunTime + LIVACCOM_EtaRunTime)
logInfo("AC","Total seconds today - " + LIVACCOM_TotalRunTime)
LIVACCOM_SecondsPerDay.postUpdate(LIVACCOM_TotalRunTime)
The end-result for whomever may want to use the same…
// we get the original value so we can increment in a temporary variable
var LIVoldValueRunTimetemp = LIVACCOM_SecondsPerDay.state
// given the variable retrieved might be NULL (it cannot be a number by default then) we need to check on this.. if it is NULL we are going to set the used Number value to 0, else we convert the temporary value from the variable retrieved to a "Number" to be used in the SUM calculation below
if (LIVoldValueRunTimetemp == NULL) {
//logInfo("AC","old value was NULL - " + LIVoldValueRunTimetemp)
}else{
LIVoldValueRunTime = (LIVoldValueRunTimetemp as Number)
logInfo("AC","Living Room AC Total seconds today - " + LIVACCOM_TotalRunTime)
