I’m running openHAB 2.5.0 Build #1590 on a Pi3. No issues.
I’m struggling to get a rule to fire based on a Number:Temperature item, which is a Hue Motion Sensor.
I’m trying to trigger an “alarm” when the temperature exceeds XX degrees. The item is, as below.
This triggers an Event;
2019-05-15 13:41:00.588 [vent.ItemStateChangedEvent] - HueLoftTemperatureSensor_Temperature changed from 32.87 °C to 33.01 °C
Now… my rule;
rule "Loft Temperature over 25 Degrees"
Item HueLoftTemperatureSensor_Temperature changed
var LoftTemp = HueLoftTemperatureSensor_Temperature.state as Number
if (LoftTemp>25.00)
//if (Double::parseDouble(HueLoftTemperatureSensor_Temperature.state.toString) > 25.0)
//if ((HueLoftTemperatureSensor_Temperature.state as Number) > 25.00)
sendMail("blah@pomail.net", "Loft Temperature Over 25", "Loft Temperature is currently "+HueLoftTemperatureSensor_Temperature.state)
logInfo("EXTRA", "Loft Temperature is currently "+HueLoftTemperatureSensor_Temperature.state)
else if (LoftTemp<25.00)
sendMail("blah@pomail.net", "Loft Temperature Below 25", "Loft Temperature is currently "+HueLoftTemperatureSensor_Temperature.state)
logInfo("EXTRA", "Loft Temperature is currently " +HueLoftTemperatureSensor_Temperature.state)
I’ve tried many variations. But what is not happening, is that the rule is not understanding < or >, and just triggering regardless. So I’m being told the item is over 25’c, when actually its not.
Any ideas?
