Number to String
AHHAHAHAAHAHA … right :slight_smile: :slight_smile: :smile:
https://www.wunderground.com/weather/api/d/docs?d=data/alerts
in theory there could be 19 alerts at once. I would go with three to be on the safe side (on the other hand: I hope, WU will put the alerts in the API sorted with priorities. so the most severe will come first.
The severity of the alert is also on the json, so if wu don’t put them in priority you can always create priority items and sort them that way.
Mmmm the path seems not correct.
I’ve tried also { http="[WuAlertsCache:10000:JSONPATH($.response.alerts[0].wtype_meteoalarm_name)]" }
but the value of my items is always NULL
the tree between xml and json versions is quite different
no, using this interesting tool:
http://jsonviewer.stack.hu
you are right, the path is JSONPATH($.alerts[0]
@vzorglub
the state is still NULL
Mmmm … how can I troubleshoot this piece?
2018-03-26 15:32:52.821 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoAlarm1’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:10000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]’ doesn’t contain a valid binding configuration
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:51) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:361) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:330) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:204) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:397) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:227) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:291) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
it should read like @vzorglub posted:
String Alarm1 "Alarm1 [%s]" { http="[WuAlertsCache:10000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]" }
I can only imagine, you changed your API-Key, but you didn’t change it in the http.cfg?
Unfortunately this is not the case :slight_smile: :slight_smile:
the new API Key is working fine and the http.cfg has been modified accordingly.
WuAlertsCache.url=http://api.wunderground.com/api/xxxxxxx/alerts/q/zmw:00000.1.15730.json
WuAlertsCache.updateInterval=600000
but the issue is still there.
ok. Then you just have to wait, I guess! :wink:
The Cache is filling on a 600000 interval, as your item wants a 10000 interval. :wink:
…or you adjust both accordingly. But be cautious: if you’re on a free WU-Key, you only have 500 calls per day…
that means 1 call every 180 sec right?
in my case 2 calls every 360 sec (6 mins)
They’re both msecs. So 600000 means 10minutes and 10000 means 10 seconds.
Absolutely … but what I’m looking at is the interval between EXTERNAL queries to Wu.
So, I have this http binding specific request, and a generic weather binding request. The first one every 10 mins, the second every 15 mins (as weather usually doesn’t change more frequently :slight_smile: )
Of course I’ll change the time my items will ask the cache … but this won’t impact the Wu calls per day :slight_smile:
time is running out, and I’m not seeing any update in my logs … after the issues above.
:frowning:
Still same issue:
2018-03-26 16:07:16.623 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoLevel4’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:300000:JSONPATH($.alerts[3].level_meteoalarm)]’ doesn’t contain a valid binding configuration
I’m confused right now… :wink:
leave the other binding and we have a look on http-binding and how it works:
  1. it retrieves the Content of a web-page and caches it
  2. in items’ configuration you can use the cached Content
ad 1)
that is, what your http.cfg does:
  • retrieve the JSON in your case
  • Caches it
  • every 10mins it reloads the Cache
ad 2)
your items ask the Cache every 10secs for updates. which will result in the same Content for 10mins.
My guess now was, that you had the old content for 10mins and only after that, the item got filled again.
it seems the item is not able to ask the cache because of the error above
not exactly. Have a look at your JSON. It should not contain four alerts. (last time I checked with your old API-key, it was only two).
this is now alerts[3] if there’s only two alerts, the fourth one is not found, of course. there should be alerts[0] or alerts[1]
same error for all 4 items (well, in facts 8 items):
String Http_Wunderground_MeteoAlarm1 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]" }
String Http_Wunderground_MeteoAlarm2 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]" }
String Http_Wunderground_MeteoAlarm3 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]" }
String Http_Wunderground_MeteoAlarm4 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]" }
Number Http_Wunderground_MeteoLevel1 “Level [%d]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[0].level_meteoalarm)]" }
Number Http_Wunderground_MeteoLevel2 “Level [%d]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[1].level_meteoalarm)]" }
Number Http_Wunderground_MeteoLevel3 “Level [%d]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[2].level_meteoalarm)]" }
Number Http_Wunderground_MeteoLevel4 “Level [%d]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[3].level_meteoalarm)]" }
2018-03-26 16:07:16.461 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoAlarm1’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:300000:JSONPATH($.alerts[0].wtype_meteoalarm_name)]’ doesn’t contain a valid binding configuration
2018-03-26 16:07:16.483 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoAlarm2’ could not be parsed correctly.
2018-03-26 16:07:16.510 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoAlarm3’ could not be parsed correctly.
2018-03-26 16:07:16.537 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoAlarm4’ could not be parsed correctly.
2018-03-26 16:07:16.557 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoLevel1’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:300000:JSONPATH($.alerts[0].level_meteoalarm)]’ doesn’t contain a valid binding configuration
2018-03-26 16:07:16.577 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoLevel2’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:300000:JSONPATH($.alerts[1].level_meteoalarm)]’ doesn’t contain a valid binding configuration
2018-03-26 16:07:16.606 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘Http_Wunderground_MeteoLevel3’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘[WuAlertsCache:300000:JSONPATH($.alerts[2].level_meteoalarm)]’ doesn’t contain a valid binding configuration
sorry wrong past of items:
String Http_Wunderground_MeteoAlarm2 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[1].wtype_meteoalarm_name)]" }
String Http_Wunderground_MeteoAlarm3 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[2].wtype_meteoalarm_name)]" }
String Http_Wunderground_MeteoAlarm4 “Meteoalarm [%s]” (gOutdoor, gWeather) { http="[WuAlertsCache:300000:JSONPATH($.alerts[3].wtype_meteoalarm_name)]" }
That’s strange, but as there’s not always enough warnings to fill all items (at least I hope there are some beautiful days in the pyrenees), have a look here:
The discussion is to have the alerts parsed via a rule - therefore you don’t have all the Errors in your logs:
