Numeric MQTT channels in Paper UI do not have ‘Is command’ option and as a result topic messages only produce the ItemChangedEvents but not the ItemCommans.
For Switch type channels there is such option in UI and everything works fine.
Any ideas?
Any ideas?
It is there in the latest snapshots. I suspect it is there in 2.5 M1. This was probably something that got fixed shortly after 2.4 release.
You could stop openHAB and edit the jsondb text file manually if you need to stay on 2.4. Will be fixed in a 2.5 release.
Cheers, David
Based on what I see in the latest snapshots this is already fixed. Am I wrong? I see the toggle on my Number Channels.
