I’ve just acquired a Nexia Z-Wave NX1000 scene controller, I was able to pair the device but Open have shows it as “Device Unknown”, in this case, there’s no channel created… anything.
So it has 15 customizable buttons (Labels show on a small LCD screen) distributed in 3 page of 5 buttons each…,
I’m a noob and to be honest it seems to be a really good scene controller, is someone out there that already created such device or someone that can help me to create a device (thing) file for it?
this is how it appears inside the Papper UI Things Tab:
You don’t need to create a “thing file” as such - what needs to happen is to create the database entry in the online database. A large chunk of this is done automatically by uploading an XML file that is auto generated by the OH binding.
The database guide is [here](https://www.cd-jackson.com/index.php/zwave/zwave-device-
database/zwave-device-database-guide). I’d suggest to take a look at this, but feel free to come back here and ask any questions that you will likely have and we’ll do our best to help you through.
Thanks fot all your help Cris! I’ve already created the entry and filled up all the required data, but I have the following issue that I’m not able to resolve:
thingid is > 15 characters - is this really necessary - it should just be the model number.
This is the URL, do you have any idea how to fix it, I haven’t been able to find the field to update it.
Once you’re happy that it looks ok, then press the “request review” button (or whatever it’s called). We’ll take a look and release it - you’ll then need to use the latest snapshot binding once the binding is updated.
Hi Cris! hope youre fine! I’ve already added the device and received 2 add-on updates on the openhab2 server, but the device still showed as “unknown”… already exclude it and include into the Z-Wave netwrok without any different results, do you know why this can be still happening?
I believe there should be a new OpenHAB release within the week. Looking at that device the update may or may not make it.
The database is in the process of moving to a new server. If the export from there is accurate it may make it into the release. Otherwise a subsequent snapshot would have it. When moving to the new server the export script needed to be rewritten.
I still have no luck , even though that I already have the binding updated, I still see the device as Unknown, do you might have an idea on why this is still happening? I’ve already unpaired and paired the device to validate without luck.
Current BInding version:
openhab> list -s | grep zwave
255 │ Active │ 80 │ 2.5.9.202008240335 │ org.openhab.binding.zwave
