NODE 12: Device discovery could not resolve to a thingType! Manufacturer data not known.
This is from the logs once I start searching.
<node> <deviceClass> <basicDeviceClass>SLAVE</basicDeviceClass> <genericDeviceClass>MULTILEVEL_SWITCH</genericDeviceClass> <specificDeviceClass>MOTOR_CONTROL_CLASS_A</specificDeviceClass> </deviceClass> <homeId>0xfd83ffe0</homeId> <nodeId>12</nodeId> <version>4</version> <manufacturer>0x47</manufacturer> <deviceId>0x5405</deviceId> <deviceType>0x5a52</deviceType> <listening>true</listening> <frequentlyListening>false</frequentlyListening> <routing>false</routing> <security>false</security> <beaming>false</beaming> <maxBaudRate>40000</maxBaudRate> <nodeInformationFrame> <commandClass>SCENE_ACTUATOR_CONF</commandClass> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <commandClass>SWITCH_MULTILEVEL</commandClass> <commandClass>BASIC</commandClass> <commandClass>SWITCH_BINARY</commandClass> <commandClass>SCENE_ACTIVATION</commandClass> <commandClass>VERSION</commandClass> </nodeInformationFrame> <supportedCommandClasses> <entry> <commandClass>SWITCH_BINARY</commandClass> <binarySwitchCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <isGetSupported>true</isGetSupported> </binarySwitchCommandClass> </entry> <entry> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <manufacturerSpecificCommandClass> <version>1</version> <instances>1</instances> <versionSupported>2</versionSupported> <initSerialNumber>false</initSerialNumber> <deviceManufacturer>71</deviceManufacturer> <deviceType>23122</deviceType> <deviceId>21509</deviceId> </manufacturerSpecificCommandClass> </entry> <entry> <commandClass>SCENE_ACTUATOR_CONF</commandClass> <sceneActuatorConfigurationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </sceneActuatorConfigurationCommandClass> </entry> <entry> <commandClass>NO_OPERATION</commandClass> <noOperationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </noOperationCommandClass> </entry> <entry> <commandClass>VERSION</commandClass> <versionCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <libraryType>LIB_CONTROLLER_BRIDGE</libraryType> <protocolVersion>3.42</protocolVersion> <applicationVersion>1.8</applicationVersion> </versionCommandClass> </entry> <entry> <commandClass>BASIC</commandClass> <basicCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <isGetSupported>true</isGetSupported> </basicCommandClass> </entry> <entry> <commandClass>SCENE_ACTIVATION</commandClass> <sceneActivationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </sceneActivationCommandClass> </entry> <entry> <commandClass>SWITCH_MULTILEVEL</commandClass> <multiLevelSwitchCommandClass> <version>3</version> <instances>1</instances> <versionSupported>3</versionSupported> <switchTypePrimary>DOWN_UP</switchTypePrimary> <switchTypeSecondary>DOWN_UP</switchTypeSecondary> <isGetSupported>true</isGetSupported> </multiLevelSwitchCommandClass> </entry> </supportedCommandClasses> <securedCommandClasses/> <associationGroups/> <nodeNeighbors> <int>1</int> </nodeNeighbors> <lastSent>2018-10-16 22:12:47.709 UTC</lastSent> <lastReceived>2018-10-16 22:12:47.933 UTC</lastReceived> </node>
Here is node12.xml file
