Hi All,
Ive just setup OH2 on a new machine and moved everything across. Moving the Zwave as nice and easy.
Everything is working fine but the Yale lock. It came up straight away, as a known device and the channels are visible. All the channel to item links are created and are unchanged (except for updating the Thing ID for the Zwave stick on the new machine)
Despite using the lock physically, the channels all remain NULL.
I thought using the code to lock or unlock, wakes the unit up and I’d expect the channels to populate but they are not.
Any suggestions? All other ZWave devices work just fine. It’s not a binding issue clearly as its the same binding from the old server.
Thanks!
