dastrix80
(Kris K)
August 8, 2018, 12:28am
#1
Hi Guys,
Odd issue with a Heater rule.This rule shuold only come into effect from 6am till 10am, Mon-Fri, June/July/Aug but whats happening is its kicking in at 4am when I am asleep - naturally I dont want the heater on at 4am
Log: showing it coming on/off
openhab> log:tail
04:34:59.181 [INFO ] [smarthome.model.script.FibaroEye1Temp] - Living Room Temp below 17°C, Turning on Heater
05:00:00.005 [INFO ] [marthome.model.script.speedtest.rules] - --> speedtest executed...
05:00:26.202 [INFO ] [marthome.model.script.speedtest.rules] - --> speedtest finished.
05:35:06.526 [INFO ] [smarthome.model.script.FibaroEye1Temp] - Living Room Temp above 20°C, Turning off Heater
Rule:
rule "HeaterTimer ON"
Time cron "0 0 6-9 ? 6-8 MON,TUE,WED,THU,FRI *" or
Time cron "0 0 7-9 ? 6-8 SUN,SAT *"
HeaterTimer.postUpdate(ON)
rule "HeaterTimer OFF"
Time cron "0 0 9 ? 6-8 MON,TUE,WED,THU,FRI *" or
Time cron "0 0 9 ? 6-8 SUN,SAT *"
HeaterTimer.postUpdate(OFF)
rule "FibaroEye1 Temperature Controlled Gas Heater turns on when Temp is below 1 7°C. Turns off when temp is above 20°C"
Item FibaroEye1Temp received update
val currentTemp = FibaroEye1Temp.state as Number
if (HeaterTimer.state == ON) {
if (currentTemp < 17 ) {
logInfo("FibaroEye1Temp","Living Room Temp below 17°C, Turning on He ater")
Heater.sendCommand("ON")
} else if (currentTemp > 20) {
logInfo("FibaroEye1Temp", "Living Room Temp above 20°C, Turning off Heater")
Heater.sendCommand("OFF")
} else if (HeaterTimer.state == OFF) {
if (Heater.state.toString == "ON") Heater.sendCommand("OFF")
Any thoughts as to why?
Hey Kris
First lets check your system time is correct to your regional time.
Second I recommend to add a log to the time-cron jobs. Then you see, if the get triggered.
I stumble regulary on cronsâŠand Im not sure if the expression is correct.
In an example here SUN,SAT are changed to SAT,SUNâŠ
Without an check, you set your Heatertimer alway to on, when the cron is triggered, even it is on already.
Regards
Michael
There is a fault in your cron rules, because the âONâ rule will fire at 6:00, 7:00, 8:00 AND 9:00 where the OFF Rule will fire at 9:00, so there is a good chance the HeaterTimer is switched OFF and immediately ON again.
Would be better only to switch ON once:
Time cron "0 0 6 ? 6-8 MON-FRI" or // Switch ON at 6:00:00 Monday to Friday from June to August
Time cron "0 0 7 ? 6-8 SAT-SUN" // Switch ON at 7:00:00 Saturday and Sunday from June to August
Time cron "0 0 9 * 6-8 ?" // Same OFF-Time for all weekdays
But you donât need these rules to sort out the time.
Of course, the code is not as nice as the Time cron trigger:
rule "FibaroEye1 Temperature Controlled Gas Heater turns on when Temp is below 17°C. Turns off when temp is above 20°C"
var bHeat = 1
if (now.getMonthOfYear < 6 || now.getMonthOfYear > 8 ) {
logInfo("FibaroEye1Temp","stop heating, Month = {}",now.getMonthOfYear)
bHeat = 0
if (now.getHourOfDay < 6 || now.getHourOfDay > 8 ) {
logInfo("FibaroEye1Temp","stop heating, Hour = {}",now.getHourOfDay)
bHeat = 0
if (now.getHourOfDay < 7 && now.getDayOfWeek > 5 ) {
logInfo("FibaroEye1Temp","stop heating, Hour = {} and DoW = {}",now.getHourOfDay,now.getDayOfWeek)
bHeat = 0
bHeat = 0
if(bHeat == 1) {
if (currentTemp < 17)
logInfo("FibaroEye1Temp","Living Room Temp below 17°C, Turning on Heater")
else
bHeat = -1 // do nothing
if (bHeat==1 && Heater.state.toString != "ON") Heater.sendCommand("ON")
if (bHeat==0 && Heater.state.toString != "OFF") Heater.sendCommand("OFF")
I also did a slight change in condition:
vs.
if (Heater.state.toString != "OFF") Heater.sendCommand("OFF")
because there is potentially a third state âNULLâ which would cause the rule never to switch OFF when heater state gets uninitialized for some reason.
Hello Udo, thank you. I shall try this rule - I appreciate you taking the time to look at it.
Its way above my level
I cant see where in your suggested rule you did the âslight change in conditionâ?
== vs. !=
You tested in your rule, if the Switch is ON, Iâm testing if the switch is not OFF. I explained the difference between these two conditions :).
Fair enough!
So the room this morning was 15 degrees, it didnt switch on because
openhab> smarthome:status Heater
OFF
openhab>
Did you take a look at the logs?
And by the way: what kind of Item is Heater
? If itâs a switch item, we donât need that .toString stuff:
if (bHeat==1 && Heater.state != ON ) Heater.sendCommand(ON )
if (bHeat==0 && Heater.state != OFF) Heater.sendCommand(OFF)
dastrix80
(Kris K)
August 10, 2018, 3:55am
#8
Heater is a string
String Heater "Heater" { channel="broadlink:rm3:78-0f-77-18-43-03:command" }
I did see it turned on the Heater once.
2018-08-10 08:49:15.248 [INFO ] [marthome.model.script.FibaroEye1Temp] - Living Room Temp below 17°C, Turning on Heater
And off, but nothing at 6am when it was very cold
2018-08-10 07:49:03.227 [INFO ] [marthome.model.script.FibaroEye1Temp] - Living Room Temp above 20°C, Turning off Heater
2018-08-10 09:04:19.082 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 9
2018-08-10 12:35:19.054 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 12
Hmm. And do you see updates of FibaroEye1Temp
with a temperature below 17°C?
Maybe add another logInfo() at the top of the rule, right after then
logInfo("FibaroEye1Temp","Temperature Update = {}",FibaroEye1Temp.state) // additional log line
var bHeat = 1
And maybe another at the bottom:
else
logInfo("FibaroEye1Temp","Desired state = {}",bHeat)
dastrix80
(Kris K)
August 10, 2018, 12:57pm
#10
Ill have to check the logs tomorrow morning when the temp drops! Ive added the logs in, so ill report back Thank you!
dastrix80
(Kris K)
August 10, 2018, 8:46pm
#11
Hi Udo, didnt turn on
It was below 17
2018-08-11 02:52:28.551 [INFO ] [marthome.model.script.FibaroEye1Temp] - Temperature Update = 17.6
2018-08-11 02:52:28.552 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 2
2018-08-11 02:52:28.553 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 2 and DoW = 6
2018-08-11 02:52:28.554 [INFO ] [marthome.model.script.FibaroEye1Temp] - Desired state = 0
2018-08-11 02:52:37.506 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:53:08.614 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:53:39.738 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:54:10.882 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:54:41.981 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:55:13.105 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:55:44.166 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:56:15.288 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:56:46.422 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:57:17.544 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:57:48.633 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:58:19.750 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:58:50.885 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:59:21.977 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 02:59:53.106 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:00:00.017 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest executed...
2018-08-11 03:00:23.881 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest finished.
2018-08-11 03:00:24.253 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:00:55.353 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:01:26.448 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:01:57.550 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:02:28.650 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:02:59.766 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:03:30.856 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:04:01.977 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:04:33.080 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:05:04.197 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:05:35.285 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:06:06.417 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:06:37.536 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:07:08.665 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:07:39.774 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:08:10.867 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:08:41.998 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:09:13.101 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:09:44.208 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:10:15.340 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:10:46.433 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:11:17.587 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:11:48.683 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:12:19.834 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:12:50.929 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:13:22.014 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:13:53.132 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:14:24.251 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:14:55.335 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:15:26.492 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 03:17:26.493 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 No Motion Detected! Turning OFF Living Room Lights
2018-08-11 04:00:00.007 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest executed...
2018-08-11 04:00:21.265 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest finished.
2018-08-11 05:00:00.005 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest executed...
2018-08-11 05:00:22.003 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest finished.
2018-08-11 05:38:10.814 [INFO ] [marthome.model.script.FibaroEye1Temp] - Temperature Update = 16.5
2018-08-11 05:38:10.816 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 5
2018-08-11 05:38:10.817 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 5 and DoW = 6
2018-08-11 05:38:10.820 [INFO ] [marthome.model.script.FibaroEye1Temp] - Desired state = 0
2018-08-11 06:00:00.005 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest executed...
2018-08-11 06:00:00.077 [INFO ] [marthome.model.script.crontest.rules] - Night mode off
2018-08-11 06:00:21.772 [INFO ] [arthome.model.script.speedtest.rules] - --> speedtest finished.
2018-08-11 06:21:50.078 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Motion Detected! Turning ON Living Room Lights
2018-08-11 06:21:50.080 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer created with 2 minutes
2018-08-11 06:22:30.769 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:23:01.912 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:23:33.110 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:24:14.305 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:24:45.487 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:25:16.660 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:25:47.863 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:26:18.999 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:26:50.194 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:27:21.365 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:27:52.509 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:28:23.696 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:28:54.881 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:29:26.038 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:30:07.246 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:30:38.438 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:31:09.632 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:31:40.795 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:32:11.908 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:33:06.196 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:34:02.528 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:35:13.926 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:35:45.107 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:36:16.294 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:36:47.469 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:37:18.592 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:37:49.796 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:38:20.930 [INFO ] [rthome.model.script.FibaroEye1Motion] - Eye1 Timer rescheduled for 2 minutes
2018-08-11 06:38:37.867 [INFO ] [marthome.model.script.FibaroEye1Temp] - Temperature Update = 16.4
2018-08-11 06:38:37.869 [INFO ] [marthome.model.script.FibaroEye1Temp] - stop heating, Hour = 6 and DoW = 6
2018-08-11 06:38:37.869 [INFO ] [marthome.model.script.FibaroEye1Temp] - Desired state = 0
vzorglub
(Vincent Regaud)
August 10, 2018, 9:00pm
#12
Itâs correct.
It execcuted this bit:
bHeat = 0
Saturday morning the heating will go on at 7am
dastrix80
(Kris K)
August 11, 2018, 10:02pm
#13
OK I will test it tomorrow. I had OH2 shutdown over night
dastrix80
(Kris K)
August 14, 2018, 8:50am
#14
Guys, i believe its not turning on/off because in my broadlink transform map, the commands are not âonâ or âoffâ
they are HeaterOn, HeaterOff
Do I need to modify the last IF statements with the sendcommands? I assume yes
/* Rinnai Gas Heater*/
HeaterOn=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
HeaterOff=2600480000012996111411391213121411141114111411391214113911391214111411391139121411391114113a113911141114121312391114113912141114113911391239111411000d05
HeaterUp=2600480000012b931412133713121411141114121312133714111437133714111411143713371411143713121312133714121312131213371411143713371411143713371337141213000d05
HeaterDown=26004800000128961114113a111411141114111412141139111411391239111411141139123911131214113a1139111411141214111411391139121411141139113912391139111412000d05
vzorglub
(Vincent Regaud)
August 14, 2018, 9:42am
#15
dastrix80:
I assume yes
I think you are assuming correctly. Try it and test
dastrix80
(Kris K)
August 14, 2018, 9:45am
#16
no change temp is above 20, hasnt turned off
vzorglub
(Vincent Regaud)
August 14, 2018, 9:54am
#17
Heater.sendCommand(transform("MAP", "mapfile.map", "HeaterOn")
dastrix80
(Kris K)
August 14, 2018, 11:44am
#18
It worked ok in previous rules with just Heater.sendCommand(âHeaterOffâ) though?
vzorglub
(Vincent Regaud)
August 14, 2018, 11:46am
#19
Ok, I donât know the broadlink binding
Does it automatically transform the commands through the map file?
dastrix80
(Kris K)
August 14, 2018, 11:49am
#20
Yes, you just reference the name inside the .map file, HeaterOn, HeaterOff etcâŠ
